Windows 10 Upgrade = Error 7054 on Izotope plugins
Hello Avid Users,
I'm having a problem with my System and I'd really appreciate some advice. My Pro Tools 10 with Izotope Ozone 5 and a few Waves plugins was working fine, then I upgraded my Windows from 8.1 to 10 and when next I opened Pro Tools my Izotope plugins gave me the error 7054 message and are now all inactive. I've checked a bunch of other threads and followed most of the advice I could find; reset the preferences, made sure everything was up to date, changed the amount of processors allocated to Pro Tools, and I reinstalled Pro Tools and Izotope (clean; removed everything first and then reinstalled) and still Izotope won't work; ERROR 7054. It has to be something to do with the Windows update and I would really appreciate if anyone has some advice on this. Thanks, |
Hello Avid Users,
I'm having a problem with my System and I'd really appreciate some advice. My Pro Tools 10 with Izotope Ozone 5 and a few Waves plugins was working fine, then I upgraded my Windows from 8.1 to 10 and when next I opened Pro Tools my Izotope plugins gave me the error 7054 message and are now all inactive. I've checked a bunch of other threads and followed most of the advice I could find; reset the preferences, made sure everything was up to date, changed the amount of processors allocated to Pro Tools, and I reinstalled Pro Tools and Izotope (clean; removed everything first and then reinstalled) and still Izotope won't work; ERROR 7054. It has to be something to do with the Windows update and I would really appreciate if anyone has some advice on this. Thanks, (I hope I'm including enough info for this to be informative and helpful) ----- My system: Pro Tools 10 - Izotope Ozone 5 - some Waves Processor : Quarto Core i7 @ 2.40GHz RAM : 16 GB System : Windows 10, 64-bit Op System HHD : NTFS 300GB |
Re: Windows 10 Upgrade = Error 7054 on Izotope plugins
Avid has not only not qualified PT for Windows 10, they strongly advise AGAINST it for now. I personally would roll back to 8.1 since it actually worked.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
When I updated to Win10 I had a problem with Izotope plugs authorizations. I had a different error, but if you are using a different auth type (i.e. USB key vs iLok vs local machine), the fundamental problem could be the same. Email tech support - they were very helpful in getting me reauthorized within a day or so.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Hi guys,
Firstly, thanks so much for the quick responses, I really appreciate it. ChuckS ; Thank you very much for the tip. I'll connect with them to see if it's the same problem and if they can help me sort it out as well. sw rec, Shan; Somehow, in my searching, I missed the articles about Windows 10... *Facepalm. Thanks for the links and info. If Izotope support can't help me with authentications, I'll move back to Win 8. Thanks again, this was very helpful. |
I have a test drive with Windows 10 and Pro Tools 12.2. Izotope plug-ins run perfectly here. Actually, this has become my main production drive.
Of course I don't recommend it for anyone other than myself.
OP how are you authorizing Ozone? If it's via iLok, check your Programs and Features and make sure you only have one version of the Pace iLok Manager installed.
Go here www.iLok.com and download the latest version. For some reason when installing older plugins, they install an old version of the ILM even when you have a newer version installed, at least on Windows 10. So, install your plugins. Uninstall everything iLok, then install the latest ILM and see if that works. That's what I had to do to get Ozone 5 running again in PT12 on Win10.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
So when will they approve Win 10 ? I mean it has been out for quite a while, and it is really lame you have to wait so long,considering Microsoft made Win 10 available to developers etc, quite some time ago.
I just built a new Audio PC workstation,and I just went to Win 10 Pro,I'm currently running PTHD 11.3.2 on it and so far it's working ok, the quicktime issue is a non factor now,because Apple released a version that installed on Win 10, so I just don't understand the delay. I'm running Isotope RX3 advance no problems and a boatload of other plugs Didn't mean to get off topic..... |
AAE error -7054 | indoe | Pro Tools 11 | 7 | 07-05-2013 07:44 AM |
-7054 for Audio Suite plugins | Vedat | macOS | 0 | 02-14-2012 04:33 PM |
DAE error #7054 while loading pre-installed plugins (air) | Renich | Pro Tools M-Powered (Win) | 0 | 07-08-2009 02:15 PM |
Air plugins DAE ERROR 7054 | MEAT | Pro Tools TDM Systems (Win) | 7 | 12-27-2008 07:43 PM |
DUY TDM Error -7054 | yoontek | Pro Tools TDM Systems (Mac) | 0 | 02-16-2008 03:20 PM |
