Reverberate
Decided to buy this verb after hearing so many good things. This is a tweakers dream. I loaded the Bricasti .wav files and I sure enjoy the verb. Some of the presets are pretty cool too. It's going to take me awhile to be really comfortable with all Of the options but I sure like it so far.
Sam |
Re: Reverberate
It is a ridiculously great IR playback. There is some magic in some of the IR's in there as well. I have wanted to start a thread and get into some preset sharing and some of the more complex operations of the plugin.
for instance if you go into the browser and go to the Factory 2 folder, you have direct access to the majority of the IR's (NOT PRESETS) So you can swap out IR's and still keep the preset (eq, effects, routing, modulation, etc) The Natural Plate Ir's are from an old German Plate at a buddys studio and each IR was taken about a 1/2 second apart. Very easy way to shorten or lengthen a plate without tweaking the settings, just change the IR. Dont be afraid to use some chorus or even a bit of delay to liven it up a bit and give the tails a bit of life! There is also some PCM 70 and H3000 sprinkled about in there as well.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Re: Reverberate
It's definitely a geek fest when it comes to detailed control of every parameter under the hood.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Liquidsonics Reverberate | guitardom | AAX Plug-ins | 35 | 10-10-2015 12:29 AM |
Problems with Reverberate | mesaone | AAX Plug-ins | 9 | 02-20-2014 02:07 PM |
Reverberate AAX Native Announced | Shan | AAX Plug-ins | 5 | 01-31-2013 02:06 PM |
