Old 06-09-2018, 11:05 PM
Simon Reich's Avatar
Simon Reich Simon Reich is offline
Default Re: Midi echo or duplicate notes HELP
Does a keyboard factory reset wipe all your sounds & presets in the Roland RD 700GX?
Simon Reich
Model : ASUS All Series ASUS MB Mainboard
ASUS Z97-A
BIOS : AMI (OEM) 0902 05/08/2014
Intel vPro : 9.01.01.1000
Total Memory : 16GB DIMM DDR3
Processor : Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz (4C 3.9GHz, 3.9GHz IMC, 4x 256kB L2, 6MB L3)
Operating System
Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Old 06-10-2018, 04:20 AM
Originally Posted by Simon Reich View Post
Thanks for that tip. I'll check it out & let you know the outcome. Is the program to detect midi traffic free?
Yes - freebie.
And for those on a mac the equivalent utility is snoize.
Old 06-10-2018, 04:22 AM
It won't wipe anything that was originally in the keyboard from the factory. It will erase any custom sounds and presets you may have entered.
Old 06-13-2018, 09:36 PM
I just tested my Pro Tools setup with a different controller keyboard & it is doing the same duplicate notes scenario. This is driving me nuts now!!! I know it is not midi echo, because I don't have a return cord sending two notes to Pro Tools & I now know it is not the controller keyboard that's doing it. So what setting in Pro Tools would be adding an extra note to my inputs?? As I said above, it never did this before & has only surfaced since my move from one room of my house to the other. HELP PLEASE!!!!!
Simon Reich
ASUS Z97-A
Operating System
Old 06-13-2018, 10:47 PM
Stig Eliassen's Avatar
Did you try MIDIOX as Jack suggested? Also, which pedals do you have connected, and have you tried disconnecting them before recording as a test?
Old 06-14-2018, 01:11 AM
Yes, all the pedals were disconnected, but it looks like I'll have to run the Midi map program?
Simon Reich
ASUS Z97-A
Operating System
Old 06-14-2018, 03:38 AM
Yes - run MIDIOX. I love these free utility programs as they can help diagnose issues like this. At least it will tell you if everything is getting to the computer like it's supposed to.
Old 06-14-2018, 09:12 PM
Now that I am running Midi-OX, I can see all the notes & information coming in. Because I don't understand what I am seeing, here is a screen shot. Can someone help me? Where do I go from here to stop the 2nd midi note appearing in Pro Tools? It is always a tiny short note at the start, whereas the actual note I wish to use is the long note. I did notice in the Midi-OX device selection point, I had 2 choices. 1. 3 M-Box Control & 2. 3 M-Box External. Could this be the problem? Remember, I have a Midi 5 Din plug in & no out back to the keyboard. The M-Box is connected to the computer via a USB cord. HELP PLEASE????
Simon Reich
ASUS Z97-A
Operating System
Old 06-16-2020, 04:33 PM
seanemeralds seanemeralds is offline
I know this thread is two years old and you've probably found your answer, but I came across this thread (and countless others), and absolutely NOTHING worked for me until I deleted the duplicate note via trimming the respective MIDI clip(s) back, then penciling in the note. Still kind of a pain in the ass, but I hope this helps you or anyone who is struggling here and receiving loads of complicated and unhelpful advice.
Old 06-16-2020, 06:14 PM
Ben Jenssen's Avatar
I'm not very expert on midi, but I remember noticing extra notes in the midi editor that seemed to be duplicates, I think it was a roland e-drum set, and I saw that they all had extremely low velocity. I don't think that they really were noticable on playback, but I think I found a way to select all the low velocity notes and delete them.
I don't know if this helps.
Duplicate MIDI notes? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2013 01:29 PM
MIDI Editing duplicate notes AMcG Pro Tools 9 1 10-26-2011 07:28 AM
Duplicate MIDI notes with AXIOM 61 problems proverb18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-07-2007 02:43 PM
MIDI ghost/duplicate notes problem...HELP! vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2005 08:12 AM
How do I remove duplicate MIDI notes? Rob Ruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-11-2003 02:51 PM
