Old 10-29-2003, 07:51 PM
Muxlow Muxlow is offline
Default MIDI : Pitch Bend
Let's say that I want to bend a MIDI note up one half step. I don't have a MIDI input device with a wheel to dial it in in real time, so I'm using the pencil and editing the track's Pitch Bend. This is where I get lost...
How exactly is that line measured? An unbent note's Pitch Bend line sits as zero, and when I use the pencil to 'bend' the line up, it jumps in seemingly random increments that move very quickly (it'll jump hundreds with the tiny bump of the mouse). So how many of these 'points' make up a semi-tone?
Oh, and don't say "use your ears". I need precision and want to understand how this works.
Thank!
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 11-01-2003, 03:19 PM
Default Re: MIDI : Pitch Bend
^ bump
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 11-01-2003, 09:28 PM
JasonRomney JasonRomney is offline
It really depends on your synth. Pitch bend is a continuous controller that has a range from 0 to 127. Usually the mid point (64?) is when no bending is happening. Your synth will dictate how much the pitch changes when going from mid to 127. Usually, though going from mid to 127 or 0 will change 1 or 2 semitones but it can be more than that if your synth is set for it. So just see what your synth is set to and that should help you figure it out.
Jason Romney
Sound Design Instructor
North Carolina School of the Arts
www.cd-romney.com
www.ncarts.edu/ncsaprod/designandproduction
Change pitch wheel bend range in Midi event operations phair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-24-2018 08:21 PM
Edit pitch bend midi data bwandon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2018 08:20 PM
Pro Tools LE 8 Midi Pitch Bend Problem W Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-09-2011 02:09 PM
MIDI track not reading pitch bend data? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2009 07:04 PM
MIDI Pitch bend question, please? William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-30-2006 11:53 AM
