Old 10-03-2003, 06:40 AM
jamieoliver jamieoliver is offline
Default White Noise Bursts with 6.1.1 LE M BOX
I am getting huge white noise bursts which just happen at odd times - I have to quit and restart Protools. I am running OSX 10.2.6 0n a G4 867MHz.
Anyone else get this problem?
Old 10-03-2003, 10:39 AM
DigiTechSupt's Avatar
Default Re: White Noise Bursts with 6.1.1 LE M BOX
Hi Jamie,
If you are using Waves plug-ins contact Waves about an update to version 4.0 that should resolve this.
There is a known noise issue with the 4.0 release of Waves.
If you are not using Waves plugs, check the following:
First make sure you are running the latest firmware version on the mbox:
You can download the OS X Mbox firmware updater here:
http://download.digidesign.com/suppo...irmware20x.hqx
-Make sure MBox is connected directly to the computer and not through a USB Hub.
-Since most third party USB cables do not include a bulk filter (the cylindrical lump near one end of the cable) to help reduce interference, make sure that you are using the USB cable that ships with MBox.
Also, try trashing Pro Tools Preferences: Go to Users > “your user name” > Library > Preferences and trash DAE Prefs, DigiSetup.OSX, Pro Tools LE 6.0 prefs, "com.digidesign.protools.plist" and "com.apple.audio.AudioMIDISetup.plist". Then restart the CPU.
Also, make sure you have initialized your audio drive as an HFS+ volume with Disk Utility.
Hope this helps.
Mike
Avid Audio Tech Support
Support FAQ
White noise bursts gemada Pro Tools SE and Essential (Win) 6 06-20-2011 12:51 PM
PT9 White Noise Bursts therecordinghouse Pro Tools 9 1 11-19-2010 10:12 AM
White Noise Bursts in PT9 mattytoldhatty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-15-2010 05:35 PM
white noise bursts deedpartle Pro Tools TDM Systems (Mac) 9 08-26-2009 04:22 AM
Bursts of white noise Danielle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 01-24-2004 06:30 AM
