Old 10-03-2022, 06:18 PM
lego lego is offline
Default "Session Setup" window is cut off in Pro Tools Intro [PT-296402]
Session Setup window is not opening in full, any ideas?
Windows 10
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 10-04-2022, 11:28 AM
Default Re: Intro "Session Setup" window
Same problem on my friend's computer. Does it work for anyone?
File Type: jpg 309720834_508763927338062_2626281771981642694_n.jpg (32.4 KB, 0 views)
Old 10-04-2022, 11:59 AM
I opened the session in Studio 22,9 (where the Session Setup window works as expected) and saved with the window opened, but it was still only partially visible after opening the session in Intro.
Could someone, please, confirm that it is broken for them, too? I could file the bug report then
Old 10-04-2022, 01:20 PM
Any scaling in use? What resolution is your screen? Some screens are too small(laptops, especially) and scaling other than 100% can cause a myriad of graphical issues. Running 3 screens here(all at 1920x1080) at 100% scaling and everything looks normal
One last-ditch idea; go back to classic mode instead of dark mode and see if that makes any difference
Old 10-04-2022, 01:57 PM
Thanks for checking!
I have two 1920x1080 screens, scaling is at 100%. Switching to Classic UI theme doesn't fix :-(
Just to make sure: you tested Intro not any of the higher versions, yes? When I open as Studio the window works ok.
Old 10-04-2022, 04:04 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Make sure "Run in compatibility mode" is UN-checked.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 10-05-2022, 12:00 AM
pot pot is offline
Default Session Setup window on Win 10 is cut off
The Session setup window on my Win 10 system is severely clipped - no way to enlarge it. 1920x1200, 100% scaling.
Any thoughts? Thanks.
ASRock Z490 | i7 10700K 4.3Ghz OC | 16 GB DDR4 3200 | AMD RX 6600 | RME Madiface XT | Win 10 Pro x64 21H2 | PT Intro 22.10.0
Old 10-05-2022, 06:18 AM
Default Re: Pro Tools Intro (free)
https://duc.avid.com/showthread.php?t=421894
Same problem here, let's try to find what do our setups have in common
Old 10-05-2022, 06:32 AM
pot pot is offline
K, I put my system spec in sig. This is brand new Intro installation, and literally first time I've opened the window. No other windows (incl ones you can't resize) seem to exhibit that. Have tried trashing prefs file.
Old 10-05-2022, 06:52 AM
I can't see too much in common as I'm on an older machine with W10 Home 21H1 (Polish locale), i3-7100U , 8GB RAM, plain Intel HD 620 graphic (30.0.101.1340) with two 1920x1080 displays.
I installed PT over 2022.4.
The Session Setup window opens normally when I start PT as Studio.
Session Setup included in the New Session Window minister Post - Surround - Video 10 01-24-2017 03:50 AM
Opening Session Setup Window Causes Instant Crash doubtful guest macOS 10 02-22-2013 07:01 AM
new pro tools 8 session but no mix window yummyph0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2010 06:22 PM
How to see whole session setup window??? c-post Pro Tools TDM Systems (Mac) 3 04-26-2003 10:14 AM
session setup window? nodell Pro Tools TDM Systems (Win) 2 01-04-2000 05:04 PM
