Old 05-22-2022, 02:56 PM
chonapelon chonapelon is offline
Default crackling guitar rig 6
when I use guitar rig 6 in protools I have a lot of noise like crackling. how can I fix it?
Old 05-22-2022, 03:15 PM
Default Re: crackling guitar rig 6
Also asked at https://duc.avid.com/showthread.php?t=390940 Please follow the DUC rules and do post multiple times for one problem. Doing so wastes other users time here responding to you and not being able to follow all the separate discussions.
You need to provide lots more details. Start at "help us help you" up the top of each DUC web page. See the info expected there, and standard troubleshooting steps.
Most clicks/pops are caused by trying to operate with too small an IO Buffer and "ignore errors" enabled in Setup>Playback Engine. Leave ignore errors unchecked. Set the IO buffer as large as you can and uncheck ignore errors. Does it stop the crackling. Now try to set the IO Buffer as small as you can to reduce latency. All native DAWS are always a trade off between latency and stability. Make sure to properly optimize your system to make it run well.
The other source of problems like this is improper digital clocking, e.g. if you are recording via S/PDIF, AES/EBU, ADAT etc. You need to tell us exactly what interface you are using, any outboard gear etc.
Very rarely driver problems or other things can cause this, make sure you are running a driver compatible with your OS version, and ditto for Pro Tools.
Is Guitar Rig 6 claimed to be compatible with the version of Pro Tools and the OS version you are running it on. You need to check all that.
If you are still stuck and need more help here, post a SiSoft Sandra report. As well as describe your interface, driver version, what you have done/tried etc.
Old 05-23-2022, 05:13 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
This used to happen once in a while with a plugin on input/record. Often changing the buffer to a different value, clicking OK and then changing it back to the original remedied the issue. It seemed it just required the DAE/AAE resetting. Closing and restarting Pro Tools would do the same but would take longer.
What buffer size are you running? How's the Pro Tools CPU and system usage meters?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Big Sur, Pro Tools 2022.5, Focusrite Scarlett 2i2
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
HTML code is On
Crackling noise when playback guitar recording andresfata Getting Started 23 03-07-2015 11:06 AM
Make a guitar sound like a bass guitar carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-17-2011 01:36 PM
Can I go Guitar>Pedals>DI XLR out to Eleven Rack? (using Mic input for guitar) electricfiddle Eleven Rack 5 12-12-2011 06:57 AM
tracking electirc guitar for guitar instrumental music crashhak Eleven Rack 4 10-31-2010 10:58 PM
OT: Guitar World names 100 Worst Guitar Solos Riad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-08-2004 05:54 PM
