Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 02-23-2022, 06:53 PM
off the wall's Avatar
off the wall off the wall is offline
Default MTRX Studio with Dante Virtual Sound Card
I’m going to replace my HDIO on the main PT HDX system with an Avid MTRX Studio. This is where it will live 99% of the time connected via the two digilink connectors to the HDX card in my Mac Pro tower.
What I’m wondering is if for occasional travel use would the MTRX Studio work as a laptop interface using just Ethernet and Dante Virtual Sound Card software? Ie no HDX card on the laptop.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 02-23-2022, 08:19 PM
BScout BScout is offline
Default Re: MTRX Studio with Dante Virtual Sound Card
Yes
Old 02-24-2022, 12:00 AM
Farhoof's Avatar
Farhoof Farhoof is offline
The Dante virtual sound cards becomes your interface/playback engine. The MTRX is a switchbox/matrix connected where you can input the Dante and output to analog using Dadman, but it doesn't show up in Protools as your interface. That's only when connected to Protools via digilink.
Someone correct me if I'm wrong though.
Old 02-24-2022, 10:25 AM
thx, I'm aware of how it "should" work. Just wondering if it really does. I'd like to be able to use the MTRX Studio as my laptop interface to drive my monitors when I'm on vacation, etc.
Old 02-24-2022, 01:56 PM
LukeHoward LukeHoward is offline
Definitely works, but DVS has higher latency (4/6/10ms) and I've had trouble getting it to work with the builtin Ethernet port of newer Macs. And it doesn't yet support Apple Silicon. But a new version is supposedly in testing...
https://lukehoward.com/
Old 02-24-2022, 02:37 PM
basehead617 basehead617 is offline
Jeff said something about Dante interfaces not working well or maybe even not working at all with the Mac Pro 10 GbE ports and that he recommended using a usb network adapter. Kind of sad if that is the case.. how can it possibly not work with something when these are all standards!?
Old 02-24-2022, 02:42 PM
Yup, it doesn’t work at all. I filed a ticket with Audinate almost two years ago, they originally suggested contacting Apple because it was a “hardware issue” (on a brand new MacPro7.1) before admitting they’d been able to duplicate it. There is a new release coming this year with user-mode drivers (required on Apple Silicon) and I’d be surprised if this issue wasn’t also fixed. But I have no inside knowledge.
Old 02-24-2022, 06:22 PM
Yes. Dante doesn't work with the 10GbE ports.
But works just fine with the Apple 1GbE thunderbolt dongle.
And Dante and the DADman controller both on the dongle work fine at the same time.
Old 02-24-2022, 07:25 PM
OP here.
I don’t have the MTRX Studio in hand yet but started playing around with the Dante software and PT today.
One BIGGIE is that VSC doesn’t work on the M1 Pro laptop yet (either does PT fully but I’m holding out hope for that before summer vacation :) )
I did get VIA going and it appears to work. Will see how it gets along with the MTRX Studio when it arrives. This is not a long term solution though since it only works at 48k. I do quite a bit of work at 88.2 and 96 as well.
Old 02-24-2022, 11:57 PM
Farhoof's Avatar
But why drag along a MTRX on a vacation and not just a compact TB/USB audio interface with enough outputs to connect your monitors? Or do you need all that IO and (SPKR) processing? I'm curious now ;-)
Maybe you can get a thunderbolt HD native box and connect the MTRX via digilink, skip the Dante altogether. Obviously more expensive, but more versatile as well.
MTRX Studio with Dante PciE card Goombot Pro Tools | MTRX & MTRX Studio 8 11-07-2021 12:01 PM
Dante Virtual Soundcard - MTRX Studio Setup TrentWilliams Pro Tools | MTRX & MTRX Studio 10 07-22-2021 06:52 PM
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 13 07-14-2021 10:50 AM
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 0 05-31-2021 02:36 AM
MTRX Studio and DANTE virtual sound card alvarodeiscar Pro Tools | MTRX & MTRX Studio 12 10-12-2020 01:57 PM
