Old 02-11-2022, 08:47 AM
TheMusicGuy TheMusicGuy is offline
Default Errors AAE-9173 and 'Audio Processing deadline not met' since upgrading
I recently updated to PT2021.10.0 on OS X 10.14.6 MacPro. I am constantly getting errors AAE -9173 at the beginning of every session doing nothing, just opening a new or old session. Also, getting 'Audio Processing deadline was not met' all the time as well.
I have active subscription to PT Ultimate. Avid support tells me I need to enter recovery mode (command + R) in order to Disable System Integrity Protection (SIP) https://avid.secure.force.com/pkb/ar...-Errors-on-Mac
Unfortunately I have spent hours trying to enter Recovery Mode with multiple key commands and articles from Apple. It doesn't work. Avid says they CANNOT HELP and that it is an 'Apple issue'.
If anyone has advice or has encountered this issue, I would be very grateful for any help from the community. Thank you so much!! Mark
Old 04-03-2022, 04:04 AM
mcnichols mcnichols is offline
Default Re: Errors AAE-9173 and 'Audio Processing deadline not met' since upgrading
Hi. I'm on HDX/MacPro 5.1 and Mojave, and I have similar issues with any PT versions after 2021.3.1, which worked fine. Smooth handling of even multiple instances of Zynaptiq 'De-Chirp' and other very demanding plugins, and processing reasonably evenly spread between the cores on the PT system usage meter.
All later versions I've tried won't play such sessions, giving instant -9173 errors. Indeed, just ONE instance of 'De-Chirp' or similar plugin gives a severe activity peak on two cores, with spikes of total CPU approaching 100%, and adding just one further plugin instance causes -9173's again.
Fortunately, sessions created under 2021.12 do seem to open OK under 2021.3.1, so perhaps that's a workaround for you.
Let us know if you find a better solution.
Martin.
-9173 errors Jazzbass56 Pro Tools 2020 3 06-03-2020 09:01 AM
-9173 errors... wwittman Pro Tools 2019 32 01-07-2020 03:18 AM
Dynamic Plug In Processing - 9173 etc. T-Low Pro Tools 2018 1 01-09-2019 01:22 AM
CPU 50-50% PT, 22% PC: Why? 9173 Errors dougdude9 Pro Tools 11 14 03-23-2015 03:58 PM
