Old 11-30-2021, 02:16 AM
Terry Barnett Terry Barnett is offline
Default S3 Modifier Keys
Hi all
Apologies if this has been covered elsewhere; I have not been able to find any reference to it.
I am on PT 21.10 with Eucon 2021.10.1 and on Mac OS Mojave but the modifier keys on my S3 (shift, alt etc.) are not working at all.
The corresponding keys on my computer keyboard work fine.
Is anyone else having this issue?
Many thanks in advance for any help.
Terry
Old 11-30-2021, 06:15 AM
ACECOM ACECOM is offline
Default Re: S3 Modifier Keys
Same here for months. Annoying
Old 11-30-2021, 06:59 AM
Thanks ACECOM
I've reinstalled EUCON Workstation Unified Install 20.11(Mac) from here:
https://my.avid.com/esd/Product/Download/2482
The modifier keys (and the programmed soft keys that use the commands in question) are working again.
Fingers crossed that the next update will address this.
Terry
Old 11-30-2021, 07:25 AM
Thanks Terry for this solution.
If Mr. Avid hears me, It's annoying to have to go back...
Old 12-01-2021, 12:37 AM
My pleasure.
I'm not certain what functionality I may be compromising on here with the rewind but I do use those modifier and programmed keys all the time so will take my chances.
Hoping Eddie will see this so that he can give us an update.
Take care.
Terry
Old 12-01-2021, 10:59 AM
Alex.Hofstrand's Avatar
Alex.Hofstrand Alex.Hofstrand is offline
This is a interesting issue and we are looking into it. Can you tell me if you are trying to use the Modifier Keys in conjunction with Mouse clicks in PT. Or are you not seeing them work in conjunction with surface based inputs?
Alex Hofstrand
Lead QA | Avid Live Sound
Old 12-01-2021, 02:01 PM
Thanks for the response Alex
As an example; I use the S3 'Shift' key and the mouse to select multiple clips i.e. click in first clip; hold down shift; click on last clip and all clips are selected. With the latest version of Eucon and using the S3 'Shift' key, the mouse click would just highlight the clip being clicked on but when I use my computer keyboard everything works as it should.
Similarly, using the 'Alt' key to duplicate and drag a highlighted clip works with the computer keyboard but not the S3 'Alt' key.
With the reinstalled earlier version of Eucon the S3 keys worked as they should.
Hope that helps?
Many thanks.
Terry
Old 12-02-2021, 10:23 AM
Thanks this is what we are seeing and have written up a bug for it.
Hope that helps?
Many thanks.
Terry
Alex Hofstrand
Old 12-23-2021, 03:40 PM
So ?
Old 12-24-2021, 03:49 AM
andybhoy andybhoy is offline
Hi folks, I’ve been having the same problem with soft keys. I tried the roll back patch above. Quick Q - did you have to uninstall the latest patch before installing the older one? My soft keys still don’t work (they did before I installed the latest version a few weeks ago).
Thx v much!
A
Hold Modifier keys? DBboy Avid S1, S3, Dock and Control App 7 10-27-2020 07:37 AM
S1 Modifier Keys for Logic sjgam Avid S1, S3, Dock and Control App 1 04-01-2020 07:47 AM
S1 modifier keys not set up supercharge Avid S1, S3, Dock and Control App 12 03-31-2020 01:59 PM
C|24 Modifier Keys in 8.0.3 paulmellors ICON & C|24 1 02-10-2010 08:46 AM
Modifier keys...anyone remember Workman Pro Tools TDM Systems (Mac) 7 10-24-2005 03:08 AM
