I'm running Pro Tools 2021.10.0 and haven't ever used the Track Commit or Freeze options. Can you explain the differences between them and give me real world examples of the benefits of each? Are there any Cons in using either?
My environment: macOS Catalina Version 10.15.7 (19H1519) 16 GB RAM SSD Internal Two external G-Technology SATA drives Apollo x6 with an Octo Satellite Avid S1 Avid Dock |
Great - thanks for responding.
If the search function on this site is inadequate for you, try googling like this:
Code:
> your keywords here +site:duc.avid.com
Thank you
No problem. And if you for some reason want to see what other sites say about the same thing, you can reverse the search to exclude duc.avid.com by turning that plus into minus
Personally I've never found myself using Freeze very much. It's handy if you've got e.g. some sort of panner which isn't clocked to the tempo and you want to be consistent for all the various versions of mixes you're printing. Sometimes I freeze a track just to look at the magnificent difference in the waveform pre- and post- processing. But they're just a massive pain in the neck if you or the talent suddenly decide you need to chop up the structure of the track, or even just try out various edits further down the timeline.
Anyway I'm usually too scared to use it as I'm terrified the plug-ins won't come back as I left them, especially if there's been some sort of OS (or other) software update. (Possibly irrational.) |
![]() Quote:
- create your instrument track and only have the VI plugin there - create aux track with plugins needed, route instrument track to aux - once "done", freeze or commit the VI track to mark it is "done"
Thank you all - My guess is these options at the least reduce the overall stress on the Host CPU by reducing the overhead of the track's plugins correct? Please let me know if that's accurate and if there are any other ways these are used.
Best, Rick |
Normal plugins are not often CPU heavy, but of course when you are using one, or one that requires large amount of latency compensation, it is useful. I only use it on VI's though
Commit / Freeze / Rendering Tracks causing Pro Tools to freeze or crash | iamkimosabi | Pro Tools 2020 | 9 | 05-09-2021 02:43 PM |
Commit/Freeze or something else? | joeydego | Pro Tools 2018 | 4 | 09-03-2018 02:24 PM |
Vacuum VI won't Freeze or Commit? | Bushpig | Pro Tools 12 | 8 | 12-24-2016 11:52 PM |
Commit and Freeze both cause 100% CPU usage | Steevp | Pro Tools 12 | 2 | 05-20-2016 12:07 AM |
Track commit/freeze | Thenewexhibit | Pro Tools 12 | 2 | 12-23-2015 02:50 PM |
