Old 10-29-2021, 12:44 PM
mirovaz mirovaz is offline
Default 2021.10 Import Session Data is BLANK
Hello members,
just installed the latest version of ProTools and now I cant import session data from my session template.
Ot show NO tracks at the source window.
Tried importing from different projects and the same error happens.
Any help or is this a bug?
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
Old 10-29-2021, 03:41 PM
njrsound njrsound is offline
Default Re: PT 2021.10 Bug Thread
Originally Posted by mirovaz View Post
Import Session data: I cant import tracks from other sessions. The source window shows empty. No tracks to select. Tried with different projects and the problem persist.
I've just tested this on my Intel Mac Mini 2018, Big Sur 11.6.1 across a variety of 'import' sessions and it's working fine here - maybe an M1 thing?
Old 10-29-2021, 05:24 PM
gives's Avatar
gives gives is offline
Default Re: 2021.10 Import Session Data is BLANK
Hello members,
I'll take a look when I get back in. What are you importing exactly. What file type?
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 10-29-2021, 05:52 PM
jeffro's Avatar
jeffro jeffro is offline
Working correctly here for me on Catalina and Big Sur. Might help to try with your file so if you have a session you can provide please start a support case (my.avid.com > Access the Support Center) so we can check it out.
linkedin
Old 10-29-2021, 06:14 PM
briaboy briaboy is offline
any luck?
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 10-29-2021, 06:56 PM
gives's Avatar
I'll report back tomorrow. I am done for the day
G
Old 10-30-2021, 08:41 AM
climber climber is offline
no problem with this here!
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 10-30-2021, 10:31 AM
gives's Avatar
G
OK, So I imported both OMF and AAF embedded Consolidated files from a project I had been sent for some work in LA and they loaded in perfect. So, it must be something on either the file itself or something else entirely. Again I am on Catalina
That is my report here.
G
Old 10-30-2021, 10:33 AM
gives's Avatar
Hello members,
Session data from a session template is a whole other thing. How much do you have in there?
Old 10-30-2021, 11:48 AM
gives's Avatar
OK I also tested importing a session into a template I call Dia Chain. It works just fine on OS X Catalina. I am guessing it may be a Big Sur issue.
Import Session Data or OMF Import creating regions of white noise Rob S Pro Tools 2019 0 09-23-2019 01:43 PM
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
