Old 10-27-2021, 10:58 AM
Augusta Global Augusta Global is offline
Default Control 24 - Seems To Be Shorting Out
Hello,
I have PT HD 10 with a Control 24 connected.
If you look at the picture, the area I have put a rectangle around seems to have shorted out. The entire rest of the unit works fine... faders, meters, everything else works.
If I turn the unit off and on 3 or 4 times, it might start working once and then it seems to short out again. In the area in question, it's almost as if the unit of turned off.
As a side note, I had just added a Eleven Rack to the PT system (Drivers, etc) and then this happened. I don't think the 11R has anything to do with it, but I did want to add this info. I did a fresh install of OSX and PT on a new drive just to see if the 11R install had something to do with it and the Control 24 acted just the same.
Any ideas?
PT HD 10.3.10
Control 24
Magma PE6R4-I
1-Core/5-Accel
OS X 10.7
196 I/O
Old 10-30-2021, 04:30 PM
albee1952 albee1952 is online now
Default Re: Control 24 - Seems To Be Shorting Out
I tend to agree that the 11R is not to blame, but this is going to require some serious intervention to solve. If it were me, I would be turning everything off. Then disconnect and remove the Control24 from the setup. Turn it over and remove the bottom panel and look at the circuit board that holds those controls. Locate every multi-pin connection on the PCB and pull/reseat every connection(at least 6 times). Doing that should scrape thru any oxidation buildup on the pins and sockets(remember that this is the same "vintage" design as the 002, which has the notorious power harness issue). Adding in some good contact cleaner to the process is also a good idea.
I would also trace back to the PSU and if that has a direct connection to the PCB in question, reseat at the PSU too
AVID / Digidesign ICON D-Control 32 Fader Pro Tools control w/ Surround Panner legasafe Buy & Sell 3 07-20-2019 09:54 AM
Hotkey/MIDI Message to switch Touchscreen Softkeys on Artist Control + PT | Control jimmivalentino Artist Series 3 09-07-2017 12:17 PM
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
My C8 Display is shorting out. jpoprock ProControl, Control|24, Command|8 0 03-10-2009 01:04 PM
