Old 10-18-2021, 11:09 AM
newstrings newstrings is offline
Default HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur
Greetings,
Running Mac OS 11.5.1 on a 27" 2017 iMac i7. HDX isn't recognized since the Big Sur install without adding a line of Terminal code each time I restart, which is
sudo kextload /Library/Extensions/DigiDal.kext
per the Knowledge Base.
Then functionality is restored.
Will there be a patch soon that will remedy this?
Thanks.
Old 10-18-2021, 07:18 PM
mattrixx mattrixx is offline
Default Re: HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur
Big Sur 11.6 addressed all of my kext issues, however, I do not run HDX, so cannot confirm for that.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX9+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFXII / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-19-2021, 01:02 PM
Chris Erlon Chris Erlon is offline
Having the same issue running HD Native TB, PT v2021.7.0 on OS 11.6.
I found this in another thread, which gives the terminal line you are using, but goes on to include a procedure to use if you're having to do it every time you start up:
https://avid.secure.force.com/pkb/ar...__2&popup=true
I was having the same problem getting Desktop Video to load, so I could run video out of my BMD UltraStudio. Spent hours trying different solutions I'd seen online for that . Ironically, going through the steps in the article above fixed the BMD issue immediately, but did NOT fix the Pro Tools issue! I still have to type in the terminal code every time I restart.
Chris Erlon
Old 10-26-2021, 05:10 PM
resonantRhythm resonantRhythm is offline
I've also gone through these steps...have you found any resolution yet?
Old 10-26-2021, 09:58 PM
JFreak's Avatar
JFreak JFreak is offline
Sounds like a permission problem. Repair permissions on your boot drive and try again.
Janne
Old 10-27-2021, 06:46 PM
Fixed permissions, driver is now loading however as soon as a session opens I get the message. "A time-out occurred with the audio interface".
Did a little researching and only thing relevant seemed to be too reseat the cables. Which I did...did not help. Nothing physical changed from Catalina to Big Sur...just software...so WTF is going on?
Old 01-15-2022, 11:48 PM
steven.a.williams steven.a.williams is offline
Originally Posted by newstrings View Post
Greetings,
Thanks.
Hello,
I used your Terminal command and it worked great.
I used to have a command that automatically operated whenever I started up my Mac, but unfortunately I deleted it when cleaning up startup items. The link to the avid page no longer has this command. Any idea how to do this? I can't find it anywhere. Here is that link again.
Steve
PT 2020.12.0/MacOS Catalina and the HD Native/HDX Driver jeff markham Pro Tools 2020 4 02-23-2021 11:19 AM
No sounds from HD Native after switching user accounts (macOS Sierra) Focuret Pro Tools HDX & HD Native Systems (Mac) 8 12-12-2016 05:41 PM
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
PT TDM 4.3.1 on G4-AGP w/MacOS 9.0.4? Dzerdzinsky Pro Tools TDM Systems (Mac) 3 06-22-2000 12:40 AM
MacOS 9.04 midimac Pro Tools TDM Systems (Mac) 4 04-21-2000 05:55 AM
