Old 09-30-2021, 02:34 AM
Gregor B. Gregor B. is offline
Default 'Key' Softkeys dysfunctional after S6 update
Dear All,
I don't know if this has been addressed, or if someone can verify this, but after updating S6 to 2021.6.0.181 and ProTools to 2021.6.0 some of my 'key' soft keys are misbehaving.
For instance, I have some keys that are supposed to scroll within the edit window and bring certain tracks into view.
I managed this by adding a 'key' command "cmd + opt + F" followed by another key command like "Boom[space]1[return]". The commands in [ ] brackets were added via the 'insert special key' command.
As a result, in the past, the edit window would jump to the track "Boom 1".
After the recent update, this method doesn't work anymore. Instead I will see the 'scroll to track' window, "Boom 1" will appear for a split second, then it will jump to "Boom1" without the space and Pro Tools won't be able to find that track...
I can't really wrap my head around it.
Any insight would be much appreciated!
Best,
Gregor
Old 09-30-2021, 12:27 PM
quadraphonics quadraphonics is offline
Default Re: 'Key' Softkeys dysfunctional after S6 update
I have found that after every S6 software update, that I need to re-load the softkey set. Go to the softkey page and Import your old softkey set. It SHOULD work...
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
2020.3 Update - All Softkeys gone innenhofstudios Avid S4/S6 7 05-07-2020 06:20 AM
S6 Softkeys PatrickCusack Avid S4/S6 4 05-23-2018 04:32 AM
S6 Softkeys Scope PatrickCusack Avid S4/S6 2 02-28-2018 08:09 AM
AutoTune Dysfunctional Steve@ZooWest Pro Tools 12 3 06-20-2016 02:35 PM
PT 7.3.1 completely dysfunctional: Help Eli V/d Vondel Pro Tools M-Powered (Win) 4 02-19-2007 08:27 AM
