Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 09-24-2021, 03:05 AM
Mike Rosoft Mike Rosoft is offline
Default PatchNet not saving monitor patches
Hi At my work we have System5 fusion. SC264D system computer with two dsp cards and without the analog monitor-comm interface module, madi monitoring and external converters are used.
This problem persists since the beginning and through several eMix upgrades and reinstalls. eMix version is 6.1.0 b19.5 (93592).
So the problem is, in every title, newly created from scratch or old template used, the eMix isn't saving the monitoring patches. No matter what patches are made and saved, after relaunching the title the CR main monitors are defaulted to card 1B, channel 1 to 8 (which is not convenient since the studio is wired differently and one have to manually repatch this section on every console boot). The monitor A section is getting erased, the monitor B C and D are functioning fine.
Any ideas or help will be appreciated
Old 12-17-2021, 05:16 AM
Steven1145 Steven1145 is offline
Default Re: PatchNet not saving monitor patches
There is a Registry input that you need to change, otherwise the CR will always default to that output.
It is HKEY_CURRENT_USER/Software/Euphonix/eMix/Persistent/Monitors/VariableMADIOutputs
Change the ControlRoomMADIPort entry to 28 (anything above the actual number of ports you have will work), save, and reboot.
Note: do a backup of your registry before tweaking, I am not liable for any errors you could make.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 01-15-2022, 12:00 PM
Works perfectly !
Thanks a lot !
Structure 1.1 Error Saving Patches anothercolour Virtual Instruments 9 12-27-2010 07:35 PM
Method of saving all patches at once in Structure? Stuart P. Virtual Instruments 1 04-06-2008 01:03 AM
Saving Xpand! patches davegibbon Virtual Instruments 3 12-07-2007 06:32 AM
Saving POD Patches In LE 7.3 rkaynan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 10:02 PM
Saving Patches in PT Hardnox MIDI 0 10-28-2001 06:32 PM
