Pro Tools First AIR Instruments Missing
I've tried installing the First AIR Instruments for Pro Tools First 2020.9, and while they make it to the Program Files/Common Files/Avid/... plugins folder, I only see them in the "Recall Inserts" section in the Inserts popup menu.
There was a similar issue with trying to install Spitfire LABS free instrument plugins, but I read somewhere that newer versions of Pro Tools might not allow any-old third-party .aaxplugins without some sort of license handshake so it knows they are legit? LABS appears to only be for the full version of Pro Tools according to tech support. I also tried an older version (10) of the AIR instruments plugin, but that didn't even put the plugins in the plugins folder. I downloaded the latest First AIR instruments plugin from here, I don't see it in the marketplace: https://www.avid.com/plugins/first-a...trument-bundle
Windows 10 (Latest) x64. Pro Tools First 2020.9. Latest Avid Link. Last edited by BlurpleBloop; 07-28-2021 at 09:33 PM. Reason: Clarifying latest air instruments is trying to be installed. |
Re: Pro Tools First AIR Instruments Missing
First-AIR-Instruments-18.1-Win_ba1b5a23-8aab-4ec6-9f3b-dea2793c0f0f from the Avid download page should be identical to what’s in your Avid Account – scroll down past Pro Tools 2020.9 Pro Tools Drivers To Pro Tools Plug-ins Eleven Effects Bundle 18.8 (WIN) 41.25 MB First AIR Instruments Bundle 18.10 Installer (Win) 1.25 GB First AIR Effects Bundle 18.8.1 Installer (Win) 98.08 MB First AIR Instruments 2018.3 Win (ZIP) 1.25 GB XPand!2 2018.10 (Win) 1.23 GB Extract, then right-click on installer and select ‘Run as administrator’ Once installed, locate where the plug-ins have been installed: Probably one of these Folders: C:\Program Files\Common Files\Avid\Audio\Plug-Ins or you may have a Sub-Folder like C:\Program Files\Common Files\Avid\Audio\Plug-Ins\AIR Music Technology or C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Avid Once found, exit all open programs then restart computer Launch Pro Tools Using Inserts in Pro Tools https://youtu.be/0AhjKYQzmTY |
Thanks for the welcome.
Still not showing up, I have attached below one of the Insert menus (don't see it under Instruments or Other for either stereo or mono) and one for what I see in the plugins folder. I made sure to run both the First AIR Instruments.msi installer in the zip and Pro Tools First as administrator. EDIT: First AIR Instruments also shows in Avid Link as installed.
Windows 10 (Latest) x64. Pro Tools First 2020.9. Latest Avid Link. Last edited by BlurpleBloop; 07-29-2021 at 07:36 PM. |
My bad – I’m sorry for wasting your time!
The Avid links I mentioned are for Pro Tools 2020.9 – and you’re using Pro Tools First 2020.9 (and I’m only learning about First today!) Your 1st image: click on Avid Marketplace and I’m pretty sure that First AIR Instruments is a paid extra and Avid’s in-app Store would provide the installer Xpand!2 is included in Pro Tools | First – it’s a separate installer Before buying any plug-ins for Pro Tools | First, please be aware that these will not work in the Standard or Ultimate versions of Pro Tools, if you wanted to upgrade in the future. Why not take out a Standard Pro Tools Subscription for a month or 2, to see if it’s worth spending the extra money ... I know I’d feel a bit cheesed-off if I couldn’t “take my plug-ins with me” when upgrading … especially if I hadn’t pegged this before purchasing! Pro Tools First 2020.9 https://avid.secure.force.com/pkb/ar...s-First-2020-9 System Requirements and Compatibility Windows 10 64-bit build 1909 https://avid.secure.force.com/pkb/ar...m-Requirements Avid Pro Tools | First FAQ https://www.sweetwater.com/sweetcare...ols-first-faq/ You’ll find some good tips here – use this Forum for your next Thread: Pro Tools | First Discussion https://duc.avid.com/forumdisplay.php?f=138 From the above: Free plugins can't be installed Solution: install the latest Avid Link https://duc.avid.com/showpost.php?p=...6&postcount=13 Quote:
Last edited by unkJE; 07-30-2021 at 02:25 AM. Reason: recommending: Pro Tools | First Discussion for more tips & info |
Missing presets for some of my air instruments in pt 11 | bloke | Virtual Instruments | 10 | 01-17-2017 08:57 PM |
Pro tools 10 missing Virtual instruments and audio content | Patlamm | Virtual Instruments | 9 | 12-11-2015 02:55 PM |
Missing instruments | tulip0852 | macOS | 1 | 06-20-2013 05:31 PM |
pro tools 8 instruments hang and all plugins are missing menu labels | europa78 | Pro Tools M-Powered (Mac) | 0 | 12-05-2010 06:40 PM |
Missing Rtas Instruments | bajman | Virtual Instruments | 8 | 03-11-2006 05:16 PM |
