Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
  #21
Old 11-15-2021, 10:45 AM
GroovnD313 GroovnD313 is offline
Default Re: I/O Error Regarding Output Paths
Trashing prefs worked for me. Happened the first day with the carbon but has not happened since.
  #22
Old 11-15-2021, 05:55 PM
K Roche's Avatar
K Roche K Roche is offline
After spending all weekend trying to diagnose this I think the issue (at least on my system) is when opening up a different session with a different sample rate
I think is happening with my system after upgrading to 2021.10 with the new Carbon firmware also ... I don't remember this being an issue with 2021.6 but that may also be a factor having worked mostly or maybe exclusively recording new sessions all at the same 48k
Agin what I have been doing to test this is opening up a bunch of old sessions with different sample rates
And one thing that is definitely happening is when I first launch PT and open a session it works fine, and say that session was 48k sample rate ,,, but If I then close that session and open a new session at a different sample rate like 88.2 or 96 first it takes a along time to open and the it opens with the wrong I/O and the wrong HW settings
Now there seems to be no way to correct this in either the I/O window by trying to defaulting the , Input ,Output and Buss tabes or by importing the correct I/O,,, (that was saved from a correct I/O) or by changing the HW set up which just reverts back to the incorrect set up as soon as you close it ..
I have tried all the fixes Reset Carbon trash preferences trash I/O preferences
The only that will get it back is to close PT and relaunch PT. when trying to open a new session with a different sample rate
Here are some screen shots (sorry for the big size but they seemed too blurry at any smaller size
This is what my I/O "Output" page should look like
This is what it shows when screwed up with no color boxes for the Mains or HP's and the two HP showing blank boxes and not checked. (blue arrows) and checking them makes no difference
This is the correct HW Set Up Main page with the Main Mon L-R checked and the the two HP set for Mon L-R
Then incorrect shows this and again, even if changed as soon as I hit ok it goes right back to the incorrect when reopened ?????
then the incorrect HW Line I/O page all the reference levels should be +4 and
channels 5-8 should be in "Bypass " And again even if I change to the correct setup as soon as it is closed it auto reverts to incorrect
System :
Avid Carbon interface , PT Ultimate 2022.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #23
Old 11-19-2021, 09:34 AM
K Roche's Avatar
I do have a case open with Avid and just posted a restricted video of the issue on Youtube , so we will see how it goes
System :
Enjoy the Journey
.... Kev...
  #24
Old 11-20-2021, 06:33 AM
K Roche's Avatar
I think my big question is does moving to Big Sur eliminate this, or should I go back to 2021 .6 Because none of fixes listed in this thread are having an effect ....??????????
System :
Enjoy the Journey
.... Kev...
  #25
Old 11-25-2021, 06:55 AM
K Roche's Avatar
A quick update :: I went back to 2021.7 and did not have this issue
So it's either a 2021.10 or the associated firmware update or both...
OR I specifically have a corrupted download of 2021.10 and or firmware update
Also in the Carbon Guide page 15 Reset --Default Firmware Image
#3 is not correct on my Carbon it did not reset itself I had to release the DIM button power the unit off then back on for it to come up to ready
System :
Enjoy the Journey
.... Kev...
  #26
Old 12-03-2021, 06:08 AM
LFO LFO is offline
Hi, I'm would like to know where you are with this please, I didn't update to 2021.10 seing this problem, but if it's solved, would love to get preamp control from Protools.Thanks
  #27
Old 12-03-2021, 06:41 AM
K Roche's Avatar
I have a support case going and did some exchange e-mails back and forth sending them specific info, even sent them a video ... BUT so far I have not heard anything after that ....
Here is the link to that video I sent them
https://youtu.be/jCZWaewSn_M
And yes the preamp control is nice especially if you are doing a bunch of recording And of course if you use the same sample rate for all your recording there is no issue ....... It's only when closing a session with one sample rate opening a new session with a different sample rate. Also there is a clunky work around Which is
#1 close and quit PT
#2 open Audio Midi set up
#3 set sample rate for what the new session should be
# 4 launch PT open new session and it will work fine
System :
Enjoy the Journey
.... Kev...
  #28
Old 12-04-2021, 10:48 AM
LFO LFO is offline
Thank you!! Well I think I'm going to try then
  #29
Old 12-09-2021, 08:22 AM
K Roche's Avatar
Avid ,,,,any news if this issue is fixed in the new 2021.12 version ???????????
System :
Enjoy the Journey
.... Kev...
  #30
Old 12-09-2021, 09:25 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hi Kevin,
We weren't able to fix it in 2021.12, but the team is looking into it as a high priority issue. We'll reach out when we have an update. Thanks.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Some bus paths could not be mapped to their previous output paths. Kbiastre Pro Tools 2019 4 02-02-2020 03:31 PM
PT 12.2 not importing multiple output paths Goombot Pro Tools 12 0 10-31-2015 11:17 AM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Pro Tools TDM Systems (Mac) 12 06-11-2007 11:35 AM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Post - Surround - Video 4 06-11-2007 11:34 AM
How do I select multiple output paths? syra Pro Tools TDM Systems (Mac) 5 10-21-2003 12:39 AM
