Old 06-10-2021, 02:58 PM
gtole2 gtole2 is offline
Default Artist control/ Mix not working in PT 2021.3
HI All,
I have a situation that I'm banging my head against the wall with.
I have a macpro 5.1 with Protools HD running 2021.3 on Mojave.
I just recently upgraded to Mojave from High Sierra to install 2021.3.
Since then my Artist control/mix does not work or show up in the Eucontrol app.
My ethernet is running through a netgear GS105 wich appears to be working fine.
When i plug the Artist control directly into the back of the Mac it works.
And before I upgraded both OS and PT it all worked fine.
Does anyone have any ideas what may be going on?
Old 06-11-2021, 09:24 AM
EddieJones's Avatar
Default Re: Artist control/ Mix not working in PT 2021.3
I suspect this is due to the Mac Security. Run the EUCON Installer and check remove all Apps and remove all prefs. Restart the Mac and then install EuControl 20.11.1 again.
EuControl 20.6.1.3 not working on Mojave with Artist Control and Artist Mix SvenIsak Avid S1, S3, Dock and Control App 3 10-09-2020 12:59 AM
Artist Control not working at all garnoil Artist Series 3 12-07-2016 01:27 PM
Artist Control not working with PT 11.3.2 mars100 Artist Series 2 06-04-2016 04:28 AM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 01:21 AM
PT10 LE + Artist Control and Mix via HUI (Not Working) Herbieoz Artist Series 5 08-10-2012 07:50 PM
