Old 06-09-2021, 12:16 PM
Veracuda Veracuda is offline
Default Midi playback issue/out of sync
Hi all,
I'm new to the community here so bear with me! I've been having an issue with midi playback. I have an Arturia 49 keyboard and using Spitfire Albion strings as well as Analog Lab 4 and the playback works fine when I hit return and start the song from the beginning. Anytime I playback anywhere else in the song it is out of sync.
For this particular example, I have 3 tracks of strings and a click going and it is off or the tracks are not lining up during playback. When I freeze the tracks I can play anywhere in the song and it's fine, but I'm trying to find out if there is something I have selected or if there is a clock issue that is preventing me from doing this without freezing the tracks?
It makes editing a pain right now since I have to start from the beginning for the tracks to line up correctly. Any help would be much appreciated and thanks!
Old 06-11-2021, 06:57 AM
Default Re: Midi playback issue/out of sync
Check your playback buffer setting. When recording, keep that set as low as your computer can handle(64 or 128 should be fine).
MIDI playback out of sync ? lanstrad Pro Tools 11 1 04-25-2015 11:20 AM
Issue: Elastic Audio Playback out of Sync - PLEASE HELP! derrek_clay Pro Tools 11 5 04-21-2015 10:00 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
MIDI Sync issue DonaldM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-03-2007 09:13 AM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
