Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 04-18-2021, 11:22 PM
LukeHoward LukeHoward is offline
Default Session setup logic issues with Sync X
Sync X, configured with WC In/Out to a MTRX and Loop In/Out to a HD I/O.
If I want to use the MTRX's internal clock (when not working with video), I would expect to be able to select MTRX as Clock Master in session setup, and have the Sync X send loop sync to the HD I/O.
There is a logic issue however as, as soon as the MTRX is selected as the Clock Master, Pro Tools assumes the Sync X Clock Ref is Loop Sync, and it cannot be set to Word Clock without changing the Clock Master back to Sync X. Audio sometimes works in this configuration but not always - I managed to get it into a state where pressing play always resulted in AAE errors, although it seems fine now (ignoring the erroneously reported Clock Master in session setup).
Also, a cosmetic bug: Hardware Setup displays the Clock Master sometimes as SYNC HD instead of Sync X.
Old 04-19-2021, 12:00 AM
Default Re: Session setup logic issues with Sync X
This appears to happen after changing the sample rate from Hardware Setup (with no session open). After the SR change, the Sync X is removed from the list of clock sources, the previous SR is displayed on the Sync X front panel, and the MTRX fails to lock: it receives the SR change via DigiLink but the WC is at the old rate. (The HD I/O, on Loop Sync, locks to the correct sample rate immediately.)
After closing Hardware Setup, the correct SR is displayed on the Sync X front panel, and the MTRX is locked.
When reopening Hardware Setup, the Clock and Loop Master are displayed as SYNC HD (rather than Sync X).
Old 04-23-2021, 03:54 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Thanks, Luke. We'll look into this.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Sync HD , Omni, Logic Pro X and Avid Audio Server issues... PT user macOS 0 03-07-2018 01:33 PM
96khz MTC Midi Sync Issues (to Logic Pro X) Duff Man Pro Tools 11 0 05-30-2015 02:05 AM
Not seeing SYNC IO in "session setup" mistermed Pro Tools 9 1 11-03-2011 04:46 AM
PT 5.1.1 - Sync Mode selection in Session Setup dialog David Lang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2001 12:58 AM
Protools 24 mix+ and Logic audio Sync Issues bleigh Pro Tools TDM Systems (Mac) 2 12-12-2000 05:04 PM
