Old 04-02-2021, 11:29 AM
colinato colinato is offline
Default Editing Bug after 2021.3 Update
Updated to 2021.3 and now having an issue. When trimming out the tail of a clip, the volume automation is not properly going along with the edit, leaving me with a big volume jump. Is this a bug, or there a preference somewhere that has changed on me? See image.
Protools 12.5.0 HD Native
Mac Pro 10.11.4
Old 04-02-2021, 01:29 PM
Felix Rost Felix Rost is offline
Default Re: Editing Bug after 2021.3 Update
I'm not on 2021.3 yet, but those may have the same problem:
http://duc.avid.com/showpost.php?p=2598088&postcount=1
Old 04-02-2021, 06:42 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
This is a reported bug with a fix on the way.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 04-06-2021, 03:10 PM
chadjhughes chadjhughes is offline
I'm getting the same thing...this is a REAL PROBLEM. Sound editors are really not going to like this. I'm constantly re-tracing my edits and repairing automation. We need a fix to this NOW!!! Causing me double the work.
Do you happen to know when they will be fixing this?
Old 04-09-2021, 01:34 AM
kosmokrator kosmokrator is offline
does someone know the incident/bug number of this with Avid?
Deal-breaker bug for us.
Old 04-09-2021, 07:57 AM
Hm..this bug has been around for ages. I don't think it's new to 21.3. PT will never pull the automation along unless the breakpoints are exactly on the clip borders. Not sure when this started but it's been an annoyance for a long time. I've gotten used to command-option-/ across any clip trims over the years.
F.
PTHDn 2022.7 (OSX12.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 04-09-2021, 08:20 AM
This seems different now. If I convert clip gain to automation on a track that is at unity volume across the entire track, all the new volume automation breakpoints should be at the beginning and end of clips by default, which they appeared to be. The edges of the automation are now not following my trims after doing this conversion. This is absolutely a new behaviour (for me anyways).
F.
Mac Pro 10.11.4
Old 04-09-2021, 12:55 PM
right, that must be new then. I hope that if they fix it, they fix it all the way and not so it's like the old broken way.
Old 04-09-2021, 01:22 PM
simonchase simonchase is offline
AVID aware since 2014. Shouldn't be long for a fix now.
PT Ultimate 2022.7.0 - MacOS 11.5.2 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.7.1
HTML code is On
Updating to 2021.3 Aviator7788 Pro Tools 13 05-12-2021 01:47 PM
aside from 2021 upgrade, anything else? paul_g Pro Tools 3 03-26-2021 08:25 PM
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? Cacov Pro Tools 2020 3 02-28-2021 04:22 AM
9.0.6 update - MIDI editing bug John003 Windows 13 01-09-2012 01:45 PM
