Old 03-12-2021, 01:51 PM
aadvance aadvance is offline
Default Updating S3 firmware on older rig
Mac Pro 2013
OS 10.11.6
PTHD 12.5.1
S3 direct connection to Mac
EuControl 19.7
S3 firmware 1.1.3
I’m limited to this version of PT, so no updates can be done beyond the specs I gave for the OS and PT. I did a clean install of everything when this machine was updated to El Cap, but now Eucon isn’t seeing the S3 on reboot. I have to restart Eucon in order for the board to be seen, and sometimes it might need multiple restarts. DHCP is set for the Ethernet port it’s connected to, and that same Ethernet port is selected in the Eucon section of System Prefs.
My question is: Considering the version of PT I’m using, would updating the Eucon software and/or S3 firmware break everything? All the release notes show that my version of PT isn’t compatible, but 19.7 (once the board is seen) seems to work just fine. Is S3 firmware tied to specific versions of PT? Any info on this is supremely appreciated...
Uninstall older version when updating Pro Tools 2020.5 on macOS? Dphx2 macOS 7 07-04-2020 09:36 AM
updating older PT LE on older Mac skfdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2013 01:03 PM
updating older sessions? Marvin the android 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2009 09:24 AM
Updating form 6x to 7x using older process cards dennis71 Pro Tools TDM Systems (Mac) 5 08-14-2007 11:20 AM
Help a noobie: Updating older version of Pro Tools Astar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-22-2006 02:25 PM
