Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-06-2020, 04:19 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Carbon and Windows 10?
Only info i could find about Windows and Carbon support is since Windows doesn't support AVB it will be available in the future sometime.
Any more specific timeline than that?
Would a third party AVB PCIe network adapter solution like for example the Echo Audio NIC-1 PCIe network adapter work?
Old 12-06-2020, 10:27 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Carbon and Windows 10?
Hey Christian,
No updates to share yet. But, we definitely hear the request! A third party AVB adapter isn't enough as there needs to be the AVB software stack to support it (it's native on macOS). That's the main technical challenge right now.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 12-06-2020, 10:47 AM
chrisdee's Avatar
Thanks for your answer. I dont know if this will take months or years but in the mean time could it be possible to make a rev.2 version of Carbon wirh with thunderbolt or another existing connection type that does work with Windows 10?
If yes please throw in sends/returns for all the onboard preamps. That would make it perfect as one could choose to monitor analog while tracking as i can with my Avid Omni.
Old 12-06-2020, 09:10 PM
JCBigler's Avatar
JCBigler JCBigler is offline
The actual NIC needs to be AVB enabled also. Even if Windows supported AVB the NIC would have to be AVB enabled as well. And it's a much more difficult process to do on the hardware side, which is why most NICs used in Windows machine don't support AVB. Apple can do it because they build all their own stuff and charge three times as much for it.
Also the AVB specifications, which is actually now officially called TSN (time sensitive networking), still, after more than 11 years, is not officially finalized.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools vanilla 2021.7
2018 MacBook Pro: six-core i9, 32GB, 1TB, Catalina / HD|Native-TB / Protools Ultimate 2021.7, DAPS, L-ISA Studio
Home/mobile: Focusrite Red 8Pre / Clarett 4Pre / DVS
Road/hotel: Roland OctaCaputre / Apogee One
Old 12-07-2020, 09:27 AM
The Hybrid Engine gives you sub-1 ms monitoring latency at ALL sample rates. So, monitoring via hardware sends doesn't provide much benefit in terms of reducing latency. Is that the goal of your request? Additionally, you'd give up a lot by choosing to monitor that way (no plugins, no routing through Auxes/Master Faders, very limited hardware routing for monitor paths, etc).
Kyle Splittgerber
Berkeley, CA
Old 12-07-2020, 11:02 AM
chrisdee's Avatar
Yes that was the goal of my request.
I've become acustomed to track vocals/guitar dry (except hardware preamp and compressor) analog by sending a signal from my Avid Omni pres sends to my Presonous HP60 headphone amp and mix that signal with the output from Omni line out 3-4 into Input A on my HP60. This way I get latency free recording.
I also can easily and quickly control the mix between these to sources to individual taste.
The main reason for this setup is the dreaded "blast/explosion of white noise" issue I had in earlier versions of Pro Tools. Luckily it's not been a problem for many years but it still hunts me in the back of my mind. The terrible blast was so loud that I'm afaid it has damaged my hearing. It was especially loud the way I tracked befor (through Pro Tools).
To avoid distorting the input by turning the recording Pro Tools track channel up by 6 to 9 dB to be able to hear myself properly I rather had to turn every other track down by 6 to 9 db (leave the recording channel at 0 db) and turn up the headphone volume to compensate. I guess you can imagin how the white noise blast sounds 9 db louder directly into my ears.
So with Carbon since it's 32bit will it be possible to turn up just the recording track (in the Pro Tools mixer) while tracking (6 to 9 db) wihout it distorting like it does on my Omni and Mbox 3 Pro befor that?
Old 12-07-2020, 12:01 PM
The Hybrid Engine integrates that entire low latency monitoring workflow into Pro Tools, which is why it's such a joy to track with Carbon. You no longer need external mixing hardware nor a standalone router/mixer app. I definitely hear you on noise bursts. Yuck! We prioritize any noise issues very high and address them asap if they ever crop up. That said, with digital audio there is always some risk. Putting limiters on all monitoring paths can help. Hardware limiters can also help, but that gets cumbersome. Ultimately, it's a user choice. But, our goal with Carbon is to make the best possible tracking experience we can. Keeping you immersed in the Pro Tools environment is key to that goal.
Carbon inputs are very high headroom. So, it's easy to track at a lower input gain, then increase PT fader gain, without clipping.
Kyle Splittgerber
Berkeley, CA
Old 12-07-2020, 03:46 PM
LukeHoward LukeHoward is offline
You need a NIC with a chipset that supports multiple transmit/receive queues and hardware time stamping, such as the Intel i210. There are several, but you are right that it is not so common. It will be interesting to see how Avid addresses this, particularly for laptop users.
https://lukehoward.com/
Old 12-07-2020, 03:48 PM
chrisdee's Avatar
Great. Then i hope it will become Windows 10 compatible soon. I'm excited to hear the preamps, line inputs, monitor and headphones quality.
I'm assuming all the above is noticable better sounding than my Avid Omni?
Old 12-07-2020, 06:35 PM
I'm excited for you to hear it too. 👍🏼
From input to output, it's noticeably better than OMNI. It sounds excellent.
Kyle Splittgerber
Berkeley, CA
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 04:14 PM
Cocoa or Carbon? Drew Mazurek Pro Tools TDM Systems (Mac) 7 02-17-2003 10:45 AM
OS X Carbon error Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-26-2001 04:53 AM
