Old 08-21-2020, 05:39 AM
BIG_brother's Avatar
BIG_brother BIG_brother is offline
Default Eleven Rack - Distorted audio at reboot
I have a macbook pro Retina display 2013
OS C El Capitan 10.11.16
My Eleven Rack is my audio interface. Version 2.0.1
I get distorted audio EVERY TIME I startup or reboot. I have to unplug the USB cable and plug it back in to sole the issue. Any ideas what is causing this? Im guessing a handshake? There is nothing to update as far as the eleven rack that I am aware of. I cannot update OS due to pro tools.
www.mickblankenship.com.com
POSITIVE ROCK ENERGY!
Old 08-21-2020, 06:01 AM
stormstudios stormstudios is offline
Default Re: Eleven Rack - Distorted audio at reboot
Is the Mac Sound Preferences set to use the Eleven Rack as the main output?
I know Mac has a tendency to try to force interfaces to switch the sample rate. It may conflict with the same rate set within 11R.
If you're only using 11R for the ProTools interface, then we'd need more information.
Old 08-21-2020, 08:05 AM
Describing the distortion or better posting a sample would likely help.
Distorted sound in protocols via Eleven Rack padg64 Eleven Rack 1 07-27-2015 06:35 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack not recognized after a OS boot or reboot. tengai Eleven Rack 2 02-28-2012 08:39 PM
SOLVED - Problem with the distorted sounds of the eleven rack! Koffax Eleven Rack 3 05-02-2011 10:30 AM
002 rack - distorted audio playback xeeganx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2003 06:44 PM
