Old 07-12-2020, 03:58 PM
Samba Samba is offline
Default Sustain messages when recording
I'm using Kontakt - Alicias Keys on an instrument track with a Novation Impulse 49 + sustain pedal.
When not recording, sustain pedal works fine.
When I hit record, the sustain pedal stops working, and the instrument track sustain stays 'on hold' - no matter how often I press the sustain down and up, it doesn't work - the sustain message just stays on.
Im running latest version of PT.
Any ideas?
Thanks!
Old 07-13-2020, 04:57 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Sustain messages when recording
Originally Posted by Samba View Post
Any ideas?
Thanks!
That's an interesting one. As simple as this may sound, did you try just turning the Novation off and back on? Or, unplug the sustain pedal and plug it back in? I've had similar issues in the past, and just rebooting the controller and/or unpluggin the pedal and replugging it seemed to solve it. Of course, you'll need to exit PT first, then do the reboot on the Novation, and then reboot PT.
If you've tried all that, or try it and it doesn't solve the problem, then I'm not sure where to look next. Its odd the sustain would work when just playing but then go bonkers when trying to record on the same track with the same VI. Good luck.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 07-15-2020, 04:57 AM
Hi Donald, yep tried everything. It's happening intermittently. Today I have a different issue that has also been happening intermittently -
My instrument track sometimes does not recognise my sustain message - The sustain message is visible in the instrument track, but pro tools is ignoring it!
Pro tools & midi = weird
Old 07-23-2020, 08:04 AM
DonaldM's Avatar
I got nothing! Sorry! Not sure where you could even begin to troubleshoot this one. Might let Avid know. Could be some kind of bug with using Novation or something. I have no idea!
Sustain NOT recording in pro tools 9!!! geoffvernon Pro Tools 9 7 03-29-2014 04:38 PM
PT 11 Sustain Problem while recording Connor macOS 9 12-25-2013 11:03 AM
Double notes when recording w. sustain? Sandager 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-07-2007 01:09 AM
midi sustain pedal messages bug dmuckala Pro Tools TDM Systems (Mac) 34 09-11-2007 10:32 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
