Old 07-09-2020, 04:55 AM
erikogermany erikogermany is offline
Default Eleven Rack Editor crashes Windows
Hi everybody,
I recently completed a new computer build running Windows 10 64-bit (Educational edition). Hardware is new i5-10400 processor on an ASUS Z490-P motherboard, 32GB RAM. I also upgraded Pro Tools to the new 2020 version.
I also have a Focusrite Scarlett 8i6 and Eleven Rack interfaces.
When doing my recent clean install of Windows, I've had repeated issues trying to install the Eleven Rack editor: after completing the install process ("You need to restart your machine to complete the install..."), the system fails to reboot, never making it past the 1st few seconds of the reboot. I get a blue screen informing me that Windows failed to boot, and that it will try and repair itself. It fails to do so, and if I try and repair windows, it eventually has to resort to a clean install again.
The Eleven Rack is running Firmware 2.0.1 (expansion pack). I've installed the latest drivers (1.1.11), and installed the expansion pack software (omitting the firmware upgrader, since I already the most up-to-date version).
Using a Macrium Reflect disc image (after ONLY windows install), I've done this perhaps 6-7 times now. I've tried the Eleven Rack Editor first (after drivers, etc.), I've tried installing after installing Pro Tools and accompanying Plug ins (with PACE, iLok software, so I don't think that's the issue with the Editor). All other drivers for motherboard are up-to-date. No pirated software or cracked plug-ins.
Previous build running same Windows software (10, 64-bit, Edu ed.) on a i5-4th gen with Pro Tools 10 had no problems with the editor. Eleven Rack is otherwise 100% functional (current Pro Tools uses it with full functionality)
Any ideas?
Old 07-26-2020, 01:59 AM
erw erw is offline
Default Re: Eleven Rack Editor crashes Windows
The same thing happens to me either.
I don't know what to do.
Did you overcome it?
Old 08-09-2020, 08:39 PM
KGraham045 KGraham045 is offline
I am having same issue I have decided not to use it. It worked fine until the Windows 2004 build ... https://docs.microsoft.com/en-us/win...0-version-2004
Old 09-02-2020, 02:20 PM
K-Rodz K-Rodz is offline
I’m having the same problem. I can confirm that the problem has to do with the windows 10 update. I had to install Windows in the first attempt and I. The second try was able to repair windows without loosing any files and other software.
I will recommend not to instal the new windows update if you’re using the Eleven Rack Editor.
Old 09-07-2020, 06:23 AM
frankpc frankpc is offline
Default Re: Eleven Rack Editor crashes Windows ver. 2004
Yes. With the Eleven Rack Editor installed in Windows v 1909, you cannot successfully upgrade to Windows version 2004.
I removed the Editor and then was successfully and consistently able to upgrade Windows 1909 to version 2004. Then while in v. 2004, I reinstalled the Editor, which calls for a reboot. Upon reboot, Windows crashes and the only way out is to remove the upgrade - reverting back to Windows 1909.
Good news is I did that three times as I tried to find a solution. And the Windows 2004 BSOD menu allows easy removal of the upgrade and returns you to v 1909 with nothing out of place.
After returning to Windows 1909, the Editor installs normally.
Has anyone been able to use the Editor with Windows 2004 ?
Windows 10 Home x64, Gigabyte Z97X-SLI MB, Intel i5 4690K CPU @ 3.5 Ghz 8.0 GB RAM, 1 TB SSD, PTF 2019.6.0.
Eleven Rack, Line 6 POD HD Pro X & FBV MKII, Fender Mustang IV V2, Shenandoah Acoustic 85
Old 09-07-2020, 09:51 AM
Night Rider Night Rider is offline
Hollers!
Same problem here. Clean Win10 (v2004) gets into boot loop after required reboot during Eleven Rack Editor install. Eleven Rack driver installs ok tho.
I'm quite confident that this ancient version of Pace/iLok is the cause. 11R Editors installer does not recognize latest version of iLok installed and forces you to install this legacy version of Pace/iLok and this is where the problem starts.
Very similar story in another thread and posssible solution as well:
Search for thread "411117" (Legacy PACE license support crashes...) in forums Pro Tools Software > Windows section. I can't post links yet. :)
Please note that I haven't had time to confirm this solution with my 11R setup yet. Let me know if this workaround works, thanks.
BR
Old 09-07-2020, 11:10 AM
Thank you N.R. !!
Per your advice, I went to the other thread you mentioned and I posted there. Seems the plan is to use a newer license and to avoid using the legacy license.
http://duc.avid.com/showthread.php?t...upport+crashes
I will give it a shot. I think that could be done in build 1909 prior to the upgrade.
It would seem that after a year or so, most people will have upgraded to W10 build 2004. And neither ProTools nor the Editor will work unless Avid takes some action.
Frank
Old 09-07-2020, 11:30 AM
From thread 411117:
"When PT11 prompted the install of PACE License Support (as it always did, even though I had the newest version already installed), I clicked install, as I was always forced to do in order to continue. But, when Windows 10's action center popped up, asking if I trust the developer and wanted to install the software, I hit DON'T INSTALL. The PT11 install software did not error out and continued on as normal, allowing me to install PT11!"
Solution above is for Pro Tools 11 (and PACE), but I guess this would work with Eleven Rack Editor issue as well. Note that Windows UAC should be enabled for this method to work and latest iLok License Manager should be installed for Eleven Rack Editor to run. And still, I haven't tried this by myself yet.
BR
Old 09-07-2020, 12:04 PM
I downloaded and installed the new iLok Manager in W10 build 1909. The older license (2.3...) was replaced with a newer version... 5.3... something. So that went well. I was still able to run the 11R Editor.
I am currently upgrading to build 2004. Still waiting for that to finish.
UPDATE: It worked !! This is the fourth or fifth attempt I've made to upgrade to Windows 10 build 2004. Simply updating the Pace license to 5.3.0.3277 (64 bit) enabled the upgrade to happen. And all I did was install it -- it removed the existing older license.
Thank you Night Rider for the tip !!
Frank
Old 09-08-2020, 06:24 AM
Default Re: Eleven Rack Editor crashes Windows [SOLVED]
Solution for Windows 10 v2004:
- Download latest iLok License Manager
- Install 11R driver and 11R Editor with PACE
- DO NOT RESTART when prompted
- Install latest iLok License Manager
- Restart
- Run 11R Editor installer once again
Voilà!
Solution for upgrading to Windows 10 v2004:
- Update PACE/iLok before upgrading to Win10 v2004
BR
Eleven Rack Editor 57Stratocaster Eleven Rack 4 08-22-2016 11:12 AM
Problems ! - Eleven Rack Editor- Windows Twelve Entertainment Eleven Rack 4 02-20-2016 03:29 PM
Eleven Rack standalone editor won't install on Windows 8.1 prkaye Eleven Rack 2 03-28-2014 10:11 AM
Eleven Rack Editor - Always On Top (Windows) Benoni Eleven Rack 4 01-24-2014 11:54 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
