Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 03-11-2020, 05:37 AM
oortone oortone is offline
Default Where is the map options pop-up?
Learning midi cc-control in Pro Tools Ultimate, the online manual mentions "Map Options pop-up menu" to assign, edit and saving/loading midi control mappings.
Where can I find this pop up? If I right click on an instrument plugin parameter I get a pop up with "learn" as only option.
The manual also mentions a "learn button" in the plug in window but I can not find it in the form of a button.
Old 03-12-2020, 09:37 AM
Default Re: Where is the map options pop-up?
Disclosure triangle right next to the word "Map" top of the plug in window, right here:
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2021.6 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock.
Also running a 2013 nMP / HDX / S6
Old 03-13-2020, 01:29 AM
Thanks, it seems like this is only available in the HD version. That's why I couldn't find it.
Two ProTools Ultimate (v 2019.6 and 2019.10) running natively on Minimac I have access to does not have this extended mapping functionality. The help files on the systems directed me to pages mentioning the function anyway.
I have acces to one system running Ultimate v 2019.6 on (a quite old) HD-system. Here I can find the mapping function as described in your picture.
It's a bit confusing since the softwares all have the same name.
Old 03-13-2020, 01:42 AM
Ah... I found another difference. The system with mapping functionality mentions Toolkit: Heat and Machine Control. Maybe that's the reason?
Options for going to PT 12 HD drumzalicious Pro Tools 12 4 12-23-2015 05:55 AM
Help: what are my options ETMuz Pro Tools HDX & HD Native Systems (Mac) 7 12-30-2013 02:38 PM
What's my options? PT 9 HD to 10 HD acmost Pro Tools 10 3 08-14-2013 04:10 PM
Q...re; BTD options lemix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-08-2004 09:04 AM
HD IO Options Centurion Pro Tools TDM Systems (Mac) 8 08-19-2002 03:01 PM
