Old 01-14-2020, 04:14 AM
Finnmaker Finnmaker is offline
Default S1 Surface Shift to Shift soft key
Hi! Is there any way of tying the Surface Shift key to the bottom left shift in S1(or making a soft key in the app etc)? I tried going through the possible commands in EuControl and manuals, but couldn't find a way.
I'm using the regular shift and other controls from my keyboard and the Surface Shift is just an unnecessary stretch away, but I find myself using it quite a bit. I have bad wrists from editing tons and try to save them as much as possible.
Thx!
Old 01-15-2020, 08:03 AM
EddieJones's Avatar
Default Re: S1 Surface Shift to Shift soft key
Not at this moment but good idea
Old 01-15-2020, 01:07 PM
Ok. Thanks for letting me know. Hopefully it would be added. :)
Old 11-24-2021, 02:03 PM
TheBarnOnMaple TheBarnOnMaple is offline
I realize this is an old thread but I've just purchased the S1 and am wondering if there's been any addition to the Eucon software that now makes it possible to assign the Surface Shift Function to a user S1 track color key. The positioning of it in the top left is hard on the wrists from an ergonomic standpoint and I'd gladly give up a user key to have this functionality as an option along the bottom row.
Old 11-24-2021, 02:06 PM
EddieJones's Avatar
There isn't a way currently. I'll bare it in mind for the future
Old 11-24-2021, 02:15 PM
Thanks kindly for the update. The main function (as I bought the S1 for mixing) that seems cumbersome and causes wrist pain is reaching the the top left corner every time I want to cycle a tracks automation state. Is there a way to cycle through a tracks automation state by programming a user key? I can see an option to specifically select touch, latch etc.. but I didn't find an option to cycle through via a user key.
Old 11-24-2021, 03:38 PM
BScout BScout is offline
In EuControl Settings, check the box (center column) "Rec/Auto switch press changes automation modes. SHIFT+Rec/Auto switch press enables track record"
For everyone I work with and myself, that's a better use to keep that on and then you cycle by just pressing the Rec button on the channel. When you want to record, then you use the shift key.
You can also set that EuControl option to a user key to toggle its setting (Soft Keys > Surface > Options > General > Rec-Auto Changes Automation) and then when mixing, you can switch it on so automation is prioritized on the Rec buttons and when recording you can toggle it off so record is prioritized. That way you don't need to use the top shift key at all.
Hope that's helpful.
Pro Tools Ult 2022.5, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 11-24-2021, 05:24 PM
That’s perfect ! Thanks so much for the recommendation, it’s far more useful in that configuration :)
Old 11-25-2021, 07:22 AM
Thanks so much BScout! I seemed to have missed that box in Eucon and it's exactly the default functionality I was hoping for on the S1
Shift-S cmbourget Pro Tools 2018 0 10-06-2018 07:25 AM
S6 Bug Report: Shift Modifier Latching with Soft Keys Dan Smith Avid S4/S6 3 05-29-2016 01:39 PM
How to turn Soft Key on AC into SHIFT key? digidesigner Artist Series 0 03-11-2013 06:50 AM
Need to use shift key mingustoo Pro Tools M-Powered (Win) 0 09-03-2008 10:21 PM
Explanation for FORMANT shift in Time Shift Plug In, please! Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2007 11:00 AM
