Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 06-21-2019, 10:44 AM
MarcOFB MarcOFB is offline
Default No Dynamics on Mixbus on System 5
Hi all!
I wanted to send my mix from pro tools through mixbus A on my system 5 Fusion.
I got the routing going just fine, however on my mixbus A only dynamics can be “enabled” and i can manipulate the parameters but it dosent get any signal through it? And the EQ cant be enabled ?
Is this my mixer model causing this? Or have i overlooked something with the Mixbus?
Old 06-22-2019, 07:55 AM
Ulf Ulf is offline
Default Re: No Dynamics on Mixbus on System 5
Hi Marc!
I have made channel 23 and 24 on the S5 with is my analog return from my SSL Sigma (PT analog summing) routed them to Mix bus A left(23) and right(24). I have made one Stereo Master in Patchnet (under Masters) and when I call up that master from slaves on my 402 I can the access eq, filters and dynamics for my master output A. Hope that was one way for you to get eq and Dyn on your master A??
Best regards Ulf
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 06-22-2019, 11:10 PM
Cheers Ulf, ill give that a try!:)
ReaRoute-PT/Mixbus martinaston Pro Tools 12 4 06-25-2017 09:34 AM
S6L mixbus into mixbus routing workaround Hitsoundtech VENUE Live Sound Systems 1 12-06-2016 11:01 AM
FS: Solid State Logic SSL X-Rack system with 4*XR618 Dynamics modules Recallbeats Buy & Sell 0 11-22-2014 04:08 AM
Expander Gate/Dynamics III vs Drawmer Dynamics DaveSB Pro Tools TDM Systems (Mac) 14 01-31-2007 05:26 AM
Digi Dynamics Plug-In Causing System Crash rob1 Pro Tools TDM Systems (Mac) 3 04-15-2003 01:44 PM
