Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-06-2019, 10:53 AM
Matt Darcy Matt Darcy is offline
Default protools an icon platform M+ - cannot communicate stable
After a busy christmas I finally sat down to setup my icon platform M+ with my protools 2018.10.0 setup on my mac.
All pretty easy to setup, power, USB into mac, update the firmware to current 2.03 - use the platform M+imap app to update and connect.
Follow the online quick start from icon https://s3.amazonaws.com/assets.icon...-Pro-Tools.pdf, setting the m+ mode to HUI inline with the 2.0 firmware changes
all pretty straight forward.
boot the m+ and protools, the faders slide once to "ready" position then I get a pro-tools error
"Pro Tools is unable to communicate with the HUI, Power-cycle the HUI and check it's connections, Note, if HUI is not in use, update the Peripherals dialog to prevent further warnings"
basically, I can't talk to your controller.
tried a few different USB cables (not got a huge amount of the type 2 cables spare same result.
Any one got their M+ working with 2.03 and pro-tools or seen this problem ?
Old 01-06-2019, 12:00 PM
Default Re: protools an icon platform M+ - cannot communicate stable
managed to get it to connect for a few seconds before the popup and move a fader, the D2 screen that's connected to it then gets a load of garbage on it and the faders are clicking very quietly and fast, almost as if it's getting loads of data and moving the faders 100 times a second and the click is the "setting" of the fader position.
Old 01-06-2019, 03:40 PM
The Weed's Avatar
The Weed The Weed is offline
Way out of my league here, just a thought. The controller is USB 2.0. Are you using a USB 2.0 port?
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-07-2019, 12:26 PM
controller is usb2 it's plugging into a mac with a usb 3 port only (no usb 2) but I did think of that and tried it with a usb2 hub plugged in, just for interest (as I had a similar problem with the ilok) no dice, but a great suggestion, so thank you.
Icon platform m+ jchan Pro Tools 2018 11 12-30-2020 08:42 AM
HUI Issues with Icon Platform M+ and PT12 Mac Mark Roberts Pro Tools 12 7 11-18-2019 10:35 AM
Waves Edition iCon Platform M Alex TCH Avid Pro Mixing General Discussion 1 08-21-2018 01:55 AM
HD not a stable platform? ADC issue + more! Help! freedomof81 Pro Tools TDM Systems (Mac) 6 12-18-2009 10:28 AM
Most Stable Platform for Digi002 kojak General Discussion 4 02-20-2009 07:48 PM
