Old 11-11-2018, 04:59 PM
Myles83avid Myles83avid is offline
Default Command 8 working with 2018?
Hey so my command 8 worked immediately when I first got it and was using PT12. I upgraded to 2018 with the exact same setup and now it stays offline no matter what I try (selecting/unselecting in peripherals, using different midi channels, restarting, re downloading and installing drivers from the avid site, I even tried hooking it up with a midi/usb interface connecting the command 8 with MIDI in/out and a motu into my mac via usb....)
Mac Pro 3.46GHz Westmere 6-Core 32GB
sierra os 10.12
Old 11-11-2018, 07:39 PM
YYR123's Avatar
YYR123 YYR123 is offline
No drivers for C|8 necessary
You should trash prefs and try again.
Does the system go into utility mode? Does all the fader cal, etcétera?
I would plug the system up via USB directly to the MP.
Also try to change the USB port on the MP to see if that’s an issue
I would also try an install an old version of 12, and see if that makes a difference
Daniel
Old 11-12-2018, 01:55 AM
PhiBee's Avatar
PhiBee PhiBee is offline
Default Re: Command 8 working with 2018?
sierra os 10.12
Strange issue, I’m still using it under HS (10.13.6) and Pro Tools 2018.10.
Did you changed or added something after you’ve upgraded ? Another control surface? Keyboard ? C|8 doesn’t like sharing :)
WIP house Prod - home studio
iMAC 4K i7 - 11.6.1- Pro Tools Ultimate 2021.10 - Audient iD22 - Behringer ADA8200 - Digidesign C|8 / Presonus Faderport. NI KK A61. LNA Video Slave 4.
STUDIO PRO Post-prod
MAC Pro "Trash can" - 10.14.6 - Pro Tools HDX + Ultimate 2019.12 /Avid C|24/S3/ProTools|Dock. Blackmagic.
Command 8 work with high sierra and 2018.xx? analog orange ProControl, Control|24, Command|8 6 05-12-2019 06:41 PM
Command 8 - Meters Not Showing in 2018.7 Siegfried Meier Pro Tools 2018 7 03-16-2019 11:12 AM
August 2018 - a day is coming D-Command ES mgoorevich ICON & C|24 9 08-23-2018 05:11 PM
PT 2018:1 - video engine not working (for some) noiseboyuk Pro Tools 2018 13 04-05-2018 09:21 PM
Track preset key command PT 2018 tomdiek Tips & Tricks 1 03-03-2018 12:52 PM
