Old 08-01-2017, 11:52 PM
bikkuri bikkuri is offline
Default Unable to write automation
Good day
I'm unable to write automation in Pro Tools in real time with anything other than volume automation. So Pan automation and any plug-in automation wont write.
If I edit automation lanes manually, that works and Pro Tools reads the automation edits when it set it to read automation.
Have checked that SAFE is off on the plugins and have toggled SAFE on and off of pan for example by command clicking.
What could be wrong? This behavior presents with any kind of record automation: write, latch and touch.
Any help would be greatly appreciated.
Regards
Bikkuri
Old 08-02-2017, 01:53 AM
Andre Knecht Andre Knecht is offline
Default Re: Unable to write automation
Hello Bikkuri,
The recording of different types of automation can be enabled/disabled in the Automation window (Command-4). Be sure to check the status there, prior to attempting the recording of any automation.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 08-03-2017, 04:42 PM
Thanks! That solved the problem I was having.
Automation: Write to End stigc56 macOS 5 11-09-2013 05:40 PM
unable to write location 0x54776152 mgentry66 Windows 1 02-03-2012 11:15 AM
Can't Write Automation!!! shawnc Pro Tools M-Powered (Win) 0 03-02-2010 04:27 AM
Automation Will Not Write (?) DMK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2006 10:38 AM
Automation Quirk...I didn't Write any Automation!! a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-20-2005 10:34 AM
