Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 08-01-2017, 11:49 AM
ccuwan ccuwan is offline
Default Importing an Audacity wave to Pro Tools M Powered
When I bring audacity wave files which are recorded externally into Pro Tools (M Powered), even though I align the tracks perfectly, the Audacity tracks are running faster then the protools and the alignment or syncing therefore changes.
Can anyone tell me what I am doing wrong
Both the Audacity and the Pro Tools are running a sample rate of 44.1 khz
Thanks for any help
Old 08-01-2017, 01:37 PM
Default Re: Importing an Audacity wave to Pro Tools M Powered
The cause will be the file/sessions are not at the same rate. Or you accidentally applied sample rate conversion to the file on import.
Old 08-01-2017, 01:47 PM
Top Jimmy's Avatar
Darryl makes a point, but I would say that you haven't provided enough info to determine anything concretely. If the timing drifts immediately, then it is what Darryl said. If the timing drift isn't noticeable until a couple minutes down the timeline, then I would say that the problem is clock drift between two unsynced digital clocks.
In other words, if you record independently on two different AD converters, you can't expect them to be in sync. The way to solve this issue would be to record in time in Audacity with a source timing track from the Pro Tools session. Whether it be a click or a rough mix doesn't matter.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 08-02-2017, 09:27 AM
Thank you both,
The drift is immediate.....I can see it within seconds of bringing the track in.
That said it must be sample rate.
I had made the error earlier so was aware of the need to match timing but 'm confident I checked it carefully.
Jimmy, where to I check the rate for importing the wave to Pro Tools. The Pro Tools session is set up at 44.1 as is the Audacity recording. I assume there is another rate issue at the track level?
Ray
Old 08-02-2017, 10:31 AM
My problem is have two recording devices running in a single environment live. I'm using Audacity or protools with a PC laptop, to record two channels and a Tascam DP008EX to record 2 additional channels. I then try to bring both together on protools running on a mac. Syncing them has been very challenging.
Other than buy an interface with additional inputs, any suggestions?
Thanks Ray
Old 08-02-2017, 11:05 AM
Top Jimmy's Avatar
Thanks Ray
So your problem is clock drift between the PC interface and the Tascam. Your only recourse to solve the problem at the source is to use an interface with more inputs.
Meanwhile, you should be able to use Time compression/expansion or Time Shift in varispeed mode to line up your current tracks.
James Cadwallader
Old 08-02-2017, 03:40 PM
Is that in Pro Tools which is the final production platform where I bring this all together?
Old 08-03-2017, 01:22 AM
Top Jimmy's Avatar
Yes
James Cadwallader
Old 08-03-2017, 07:21 PM
Thanks to all for the help
Pro Tools can't find MBox but Audacity can... Ian_Brett Pro Tools 9 2 02-19-2012 03:47 PM
Importing with Pro-Tools M-Powered Essentials Nirrad Pro Tools M-Powered (Win) 1 03-20-2011 08:10 PM
Importing Pro Tools 5.1 (PC) tracks to Pro Tools M-Powered 8.0.3 (Mac) flash_usb Pro Tools M-Powered (Mac) 3 11-02-2010 06:27 PM
importing Audacity tracks into ProTools LE ChrisMurray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-22-2008 11:57 AM
Pro Tools Free vs. Cakewalk, n-Track, Audacity bilco Digidesign Hardware & Software 1 07-19-2004 07:32 PM
