Old 06-21-2017, 01:04 PM
martinaston martinaston is offline
Default ReaRoute-PT/Mixbus
I have been dabbling with Harrison Mixbus like a lot of other PT users. It has an excellent mixing section and the logic being that if one could use PT editing then send audio to Mixbus mixer for final mixdown...[audio export is an option but very time-consuming and frankly a big pain in the you-know-whats].
So first there is JACK which doesn't work in Windows 10 at least (I am on PC using WIN 10, PT 12.7.1 & Mixbus 32C v4).
So then a guy on the Mixbus forum told me about Reaper's ReaRoute ASIO 64 bit driver. So I installed it with a Reaper demo and sure enough ReaRoute becomes available in PT. And Mixbus.
Hey presto! Not.
Doesn't seem to communicate as audio is passed out of PT, Mixbus isn't receiving the audio stream. Lost in cyberspace, so to speak. Anyone any ideas?
Old 06-24-2017, 07:06 PM
Mr609's Avatar
Mr609 Mr609 is offline
Default Re: ReaRoute-PT/Mixbus
Does this touting technique work from PT to Reaper?? Just curious. Cuz if not, it's prolly an Avid limitation....I mean feature.
Old 06-25-2017, 02:37 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Hey presto! Not.
Reaper's routing can get a little tricky, but I'm pretty sure shan will know about this. Maybe you could PM him and find out?
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.12 | Windows 10 Pro
Old 06-25-2017, 04:22 AM
After extensive experimentation a friend of mine in Denmark and I have ascertained that ReaRoute only works with Reaper therefore PT cannot use ReaRoute to communicate with Mixbus or any other DAW apart from Reaper.
I don't know if PT can act as "Master" with Reaper.
JACK is back though and we have managed to pipe audio from PT12.7.1 into Harrison Mixbus 32C V4, although it is a tricky process and rather unreliable at this stage.
I'll post here with further developments.
Old 06-25-2017, 09:34 AM
lesbrunn's Avatar
PT can act as master. It all depends on whether or not ReaRoute is available in slave mode.
S6L mixbus into mixbus routing workaround Hitsoundtech VENUE Live Sound Systems 1 12-06-2016 11:01 AM
PTLE gain staging/mixbus questions... outoftune 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2007 12:47 PM
Matching MixBus level with track channel during calibration. ODC Pro Tools TDM Systems (Mac) 0 02-26-2002 10:51 AM
ProTools LE Mixbus - how does it compare to TDM-systems? steins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-19-2002 12:53 AM
