Old 02-01-2017, 04:39 AM
jamie1981uk jamie1981uk is offline
Default Eleven Rack - How do i mute it?
Is there any way to mute to 11R so I can hear Guitar Rig 5 only?
I'm connected to the 11R and i'm using headphones and the sound is constant. I have tried to make a patch and turn the volumes down but I can still hear the raw guitar sound when I have Guitar Rig 5 on. I want to be able to use the Eleven Rack for my base sound and the Guitar Rig 5 for additional effects that the 11R does not have. I noticed this when I was using Cubase. I get the sound with or without pressing monitor. I suppose it didn't bother me so much because I like to play over the track but it's pretty unconventional in recording terms and I need to start doing it the right way.
Thank you for any help
Jamie.
Old 02-01-2017, 02:26 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Eleven Rack - How do i mute it?
England....nice.
So I need to ask more questions b/c to me it is unclear what you are asking.
The 11rack is the main interface?
Using Headphones and not studio monitors?
What PT version are you running?
11r is hooked up to the computer via what cable?
Cheers from Central Texas USA
Daniel
Old 02-02-2017, 03:17 AM
Ichil Ichil is offline
I assume that you want to stop the direct monitoring of the 11R and use the monitor function from the DAW.
This cannot be made directly from 11R because AVID decided that this function is available only if your DAW is Pro Tools, but there's a workaround as explained in this thread:
http://www.elevenrackpresets.com/for...5071#Post45071.
You need two cables (one if you don't want to run it in stereo).
Connect from 11R's Loop Send to Line In.
Enable the Loop block in the 11R, place it last in the chain and turn down the 11R's Return level to 0 (set send level as needed).
In your DAW, choose Line In as your input and enable monitoring.
Old 02-04-2017, 01:38 PM
That's what I was looking for. I hate companies that make it hard to use other products just because they want you to use theirs. This is probably the reason why so many 11rs were shipped with pro tools. It wouldn't be hard to make a update but if it's a discontinued product, I don't see any chance of them sorting it out. I do have a few solutions but I wanted to know if it was possible with the 11r. No wonder the guy behind the 11r left the company and made the Helix if this is how petty Avid are. I wish they would let the community make updates for it. Such potential is lost in this machine.
Old 02-04-2017, 01:47 PM
Works perfect. Thank you very much for the help. Just needed to turn the fx loop mix on full and it totally muted the patch. I have one patch that is a bypass one so I can now add what ever sound I want outside the 11r.
Old 02-04-2017, 02:01 PM
I don't think "the guy behind the Eleven Rack" made the Helix. Chris Townsend was the main architect/developer of Eleven and the Eleven Rack. He went off to do other things. Other folks on the product team ended up at Line 6. But yes in many respects the Line 6 Helix looks like what a modern Eleven Rack might be.
Old 02-05-2017, 08:54 AM
bredo bredo is offline
But missing the True-Z input................. which is a real strenght of the Eleven Rack IMHO
Old 02-05-2017, 11:39 AM
Neither does the InMusic HeadRush, which I expect was part of the deal with Avid dumping M-Audio to InMusic. Which all just helps confirm the Eleven Rack is the end of the line for Avid. And InMusic's claims that that was "Developed by the team behind Avid's Eleven DSP" is never substantiated (and note that says Eleven DSP not Eleven Rack). And "the team behind Eleven DSP" as far as I can tell was really mostly Chris Townsend. And nobody is saying he was involved with HeadRush. I'm more suspecting InMusic is being less than honest here and means they licensed the code from Avid: the company/team who developed Eleven DSP. Anybody from InMusic listening? Want to back up your marketing claims with an explanation?
BTW HeadRush looks nice, but is missing S/PDIF in/out. pretty annoying for folks who want to hang it off a main interface.
Old 02-06-2017, 12:36 AM
Jay_uk Jay_uk is offline
thats a deal breaker for me.
Old 03-02-2017, 01:29 PM
bronsoncox bronsoncox is offline
Go in and change the 'Rig Input' setting on your Eleven Rack (or through the Editor) to one of the digital inputs.
Mute Eleven Rack When Tracking in Other DAW MattBaron Eleven Rack 2 10-19-2015 01:56 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven Rack - Stand Alone interface - Mute Input phwg Eleven Rack 4 02-29-2012 09:53 AM
Mute button on eleven rack, software window Sam C Eleven Rack 3 12-04-2011 01:03 PM
