Old 01-19-2017, 03:43 AM
Cimond Cimond is offline
Default Insufficient Privileges to start Low Level Driver
Hey all.
After downloading a few EastWest plugins for my university course, I began having issues when launching Pro Tools 10. Every time it attempts to load a plugin it comes up with a message saying "User privileges insufficient to start a low level driver".
It then says that the plugins were either not authorized, iLok was not connected (it definitely was), or the plugins were damaged. I attempted a reinstall but that did nothing. I attempted to download/update new iLok drivers and that also did nothing.
Other threads have suggested running the program as administrator. However, this just came up with a new error message. "This software requires installation of the InterLok(R) device drivers and TPkd device drivers and a reboot before running". AsI've already attempted to download the new drivers but it hasn't yielded any results.
I have even tried reinstalling the program multiple times and it did not help.
My PT10 version is up to date (10.3.10). I really cannot figure this out, and no other threads have helped.
Any advice will be much appreciated! Thank you for reading :)
Old 01-19-2017, 04:58 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Insufficient Privileges to start Low Level Driver
Does your user have administration rights or is it a regular user? PT must be run on admin user
Janne
Old 01-19-2017, 05:07 AM
Yeah I have admin rights. But when I run as admin it just creates more problems than if I opened it normally :/
Old 01-19-2017, 05:18 AM
JFreak's Avatar
Umm... Mac or Win? Please read the Help Us Help You document that is linked to the forum header
Janne
Old 01-19-2017, 06:03 AM
His info on his profile page says Win7 and that brings up a few thoughts:
Make sure power saving measures for the USB ports are turned of in Windows Control Panel.
Make sure the iLok is plugged in to the same port it was originally in when the ILM s/w was installed
Check that the correct ILM version is installed
Definitely run in admin mode
Don't let the computer or hard drives sleep ever
and definitely turn off any extra Windows bs that's running especially any kind of virus protection
Jack
QAPLA!
Old 01-19-2017, 05:41 PM
I reinstalled the ILM application and checked for updates, restarted the pc.
When I ran PT10 as admin it still came up with the same InterLok(R) Driver message and the TPkd message for every single plug-in it tried to load. Which is a lot of messages to click through just to close the application again.
I also checked the USB settings and those power options were never enabled.
Thanks very much for the advice, though!
Old 01-19-2017, 09:50 PM
amagras amagras is offline
Install the content on the folder "old drivers" inside the ILM installer zip
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-19-2017, 11:43 PM
Oh, amagras, I could kiss you.
I did exactly that and PT10 launched without a single error message.
Thank you so much! :)
Old 01-10-2019, 03:17 PM
For those who contacted me asking to explain this ^^, here's the video
https://youtu.be/A_tIsYWBZJs
amagrasmusic.com
Initialization Error: User privileges insufficient to start low level driver JULIN General Discussion 1 08-28-2014 09:01 PM
User privileges insuficient to start a low level driver fil_mac Windows 2 07-27-2011 04:52 AM
no permission to start low level driver??? nincompoop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-14-2011 05:37 AM
Insufficient access privileges - Protools 6.4 LE Bond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-17-2006 12:07 AM
Insufficient access privileges warning??? logicaltextures Pro Tools TDM Systems (Mac) 2 01-03-2004 05:21 PM
