Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Old 11-12-2016, 08:37 AM
yimtland yimtland is offline
Default Avid Scorch support for Sibelius Sounds 7.5
I recently downloaded and installed Avid Scorch to my iPad. I want to playback a score I created using Sibelius v8.4.2, which uses instruments from the Sibelius Sounds 7.5 package. Can Scorch also playback using these same sampled instruments? I'm assuming that the entire Sounds package would not need to be downloaded to the iPad, since only a very small number of instruments are being used in the score (cello, piano, and flute). But I would like to get the same high-quality of these sampled instruments when using the playback feature of Scorch.
Thank you in advance.
Avid scorch iOS K1ng1 Avid Scorch (iOS) Forum 6 03-15-2020 03:32 PM
Scorch won't open Sibelius files Mikel77 Avid Scorch (iOS) Forum 4 08-05-2012 07:19 AM
Scorch doesn't work with Safari 5.1. Confirmed by Sibelius! evnoic Avid Scorch (iOS) Forum 4 09-27-2011 02:34 AM
Sibelius 7/Scorch on iPad problem evnoic Avid Scorch (iOS) Forum 10 08-18-2011 04:06 AM
