Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 09-13-2016, 08:22 PM
Liam8mail Liam8mail is offline
Default Midi playback problem!
I'm using protools express with an mbox and a m-audio keystation midi usb controller. At first the controller would stop working randomly. I tried the usb powersave and so on. Eventually swapping usb hubs seemed to work. Now the problem i'm facing is at some point while working on a session the midi stopped triggering audio.
The controller is picked up by protools, the midi notes are recorded on the instrument track but there is no sound. The Midi works fine on other sessions. So I'm stumped as to why I stopped working on this one... MIDI through is checked. I played around with changing the input slot for the VI a to b to c. the output is to earphones. I put on input to check after reading it may help but no use.
Old 09-16-2016, 07:40 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Midi playback problem!
Hi liam !
Um ... I remeber to have the same behavior once and it turned out to be my m audio keystation controller . It worked fine with some cables only . At the end i had to be replaced for another controller :-/ .
BUT do you test the controller outside protools ? There is an utility to test midi hardwares in windows . It is called midiox , google it . Test differents lenght usb cables if possible .
Let me know
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 09-16-2016, 08:19 AM
Southsidemusic's Avatar
Hi and Welcome to the Community
Could you please post more info on your computer setup like PC/Mac aswell as OS. If you check your power saving features and make sure you don't have any USB port sleep mode or any other functions on as those need to be OFF.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
help!! midi playback problem. t.ross64 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-13-2010 06:30 AM
Problem with Midi Playback [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2009 02:47 PM
Newby MIDI playback problem - no audio during playback ericbpawsinc MIDI 2 03-12-2008 09:05 PM
MIDI playback Problem Larry Pate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2007 10:47 AM
midi playback problem MunchieLad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-21-2006 02:30 AM
