Old 05-08-2016, 05:51 PM
arneyz arneyz is offline
Default Randomizing Playlist Clip Colors
Hey all,
Here's an issue I've never come across before. I started doing vocal takes and noticed that every take in playlist view is the same color. I like to have each take be a different color to make comping easier.
It seems like Pro Tools usually does this automatically. I haven't changed any settings.
Wondering if anyone knows how to get these clip colors to randomize.
(NOTE: They are randomized from track to track, just not in the different takes in playlist view.)
Thanks
Old 05-08-2016, 07:39 PM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default Re: Randomizing Playlist Clip Colors
Color coding is set in the first preference pane, "display." There are different settings for clip color and track color. First place I'd check. This particular pref (at least clip color) seem to be saved with the session.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2021.10, MacBookPro i9 8-core 2.3gHz, 32Gb RAM, Mac OSX 10.15.7, SSD boot drive, SSD sample drive,
Neve 8816, HD Native PCIe, Apogee DA-16X, Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 05-09-2016, 05:01 PM
Well, the problem seems to have righted itself. Started doing takes on a new vocal track and each one is showing up a different color. I guess it was a fluke. Thank you for your help!
Old 05-10-2016, 12:04 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
With the track set to playlist view track colors will reset to blue when moving the playlists. When loop recording each playlist will be a different color and generally retain it until one of the differently colored tracks is moved to the highest priority (play track). The default color behavior for playlists is annoying.
I will choose,
Freewill
http://jimdiazaudio.com/
playlist colors undo pqlior@mac.com macOS 1 05-30-2014 11:11 AM
How do I stop playlist view destroying clip groups? clutch Post - Surround - Video 3 11-14-2013 09:27 AM
region colors in playlist swv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-31-2012 01:29 PM
playlist colors!!! jeffpardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-21-2009 09:13 AM
Randomizing DR Rex in Reason Caution767 Tips & Tricks 1 10-20-2004 07:36 AM
