Old 12-16-2015, 10:03 AM
Dizzi45Z Dizzi45Z is offline
Default Bouncing or Committing an Auxiliary Input ignores track solos.
I am trying to create stems with certain tracks and their EFX coming from the effects busses.
When I solo a track and hit playback, I hear exactly what I would like to get. But when I then Commit the Mix Bus (Auxiliary Input track that all tracks are routed to), the solo is ignored and I get a commit of all the tracks coming through. Is it supposed to work like this?
I tested it with bounce and bounce does not factor in the solo either. However, it seems like VCA's solo's are factored in. Weird... Still testing and trying to figure out when solos work on Commit and Bounce and why.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2020.5
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 10.15.4
Noisebox Studios -Utah Recording Studio
Old 12-16-2015, 10:40 AM
Default Re: Commit on busses ignores soloed tracks
Yeah, so if you assign a VCA to the track you want soloed and use the solo on a VCA it works. If try to just solo the track and Commit or Bounce, it will not honor the solo.
Can anyone else confirm this?
160 GB RAM
macOS 10.15.4
Old 12-16-2015, 10:49 AM
One other find. If you set-up a Master and bounce from the Master, the Solos are considered. So a work around is to create a Master that is on the input bus for that Aux Input and Bounce from the Master Fader.
Nevertheless, I'll bet this is a bug. So far I have defined it as:
160 GB RAM
macOS 10.15.4
Old 06-04-2020, 11:00 AM
jimax jimax is offline
Default Re: Bouncing or Committing an Auxiliary Input ignores track solos.
I confirm it's still the case.
Commit aint aligning tracks :S [solved] mirovaz Pro Tools 12 21 11-03-2016 03:59 PM
Commit Tracks and HEAT Siegfried Meier Pro Tools 12 10 11-13-2015 05:37 PM
select soloed tracks amoretam macOS 8 01-30-2013 08:56 AM
Soloing tracks that are sent to busses generalaggio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2010 12:57 PM
