Old 10-16-2015, 01:24 PM
louderock louderock is offline
Default Protools crashes during launch after installing Soundtoys update
Protools 10.3.10
iMac 3.1 GHz i7 OS 10.8.5
8 GB Ram
HD Native Thunderbolt
Omni interface
Artist Mix
Just did the Soundtoys Native update and Protools was a bit slow to open a few times but did work. I found that quitting EuCon helped. Now Protools won't open at all.
When I click the icon to open Protools, it scrolls through the plug in list and then stalls a bit on "Creating DAE Objects" but will progress to "Setting Up Peripherals looking for a sync" and then crashes.
I've uninstalled EuCon software. Trashed all preferences. Updated the HD hardware drivers. Uninstalled Protools and Reinstalled to version 10.3.10. Reset the Omni interface from the front panel. Put Soundtoys in the Unused Plugins folder. Nothing works.
I tried holding down N on startup to get the Playback Engine dialog. It always defaults to HD Native Thunderbolt - even if the Omni is turned off and disconnected. If I switch the engine to Built In Output, it just crashes again and defaults to HD Native Thunderbolt. I have been able to switch to Built In Output a few times and get the "Protools will now quit. Relaunch for new playback engine…" As soon as I re-open, it crashes again. If I am able to switch the engine and do a re-start holding N, it reverts to HD Native Thunderbolt.
I did manage to open one session and switch to Built In Output. The session would play just fine. I saved the session and tried to re-open. It crashed and on the next open I held N and the engine had switched back to HD Native Thunderbolt despite being saved as Built In Output.
I can choose HD Native Thunderbolt in my Mac System Prefs for sound output and the computer will play audio through my Omni just fine.
I can hook up the Thunderbolt/ Omni to my laptop with Protools and it works just fine.
I need Protools to work with my Omni again. Can't see how the Soundtoys update could've cause such an issue.
Old 10-19-2015, 05:10 PM
Question Re: Protools crashes during launch after installing Soundtoys update
Have you tried another OS X user account? That will help you determine if the problem is specific to a user account or if it is affecting the entire system.
Old 10-20-2015, 03:04 PM
Default Re: Protools crashes during launch after installing Soundtoys update
Not yet. I guess I just log in as "Guest"??
Update. I did get Protools to finally open and I can switch to other sessions by opening a session without closing the current one. "Open Recent" or "Open Session" and then just save the current one when prompted. Haven't tried quitting Protools yet since I have some work to do!
Old 10-21-2015, 09:56 AM
Post Re: Protools crashes during launch after installing Soundtoys update
You could try that. Another option is to create a new, administrative user and see what happens. You can delete the new user account after you establish the scope of the problem.
Old 10-25-2015, 08:19 AM
Somehow, some way, it's all working again. I uninstalled and re-installed everything, including Soundtoys, firmware, Eucon……the next step was a can of kerosene and a flame-thrower. Glad it's working but I'm a little un-confident with it right now.
Old 04-14-2016, 06:14 AM
simonchase simonchase is offline
Had this all morning, a reinstall kind of fixed it, then it came back.
And suddenly it seems to be fine again.
Pretty scary, no idea what caused or solved it.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
PT crashes on launch after update to 11.1.1 or 11.1.2 Kevin Windrem macOS 0 01-31-2014 11:13 AM
ProTools 9 Crashes at launch (Quit Unexpectedly) ChrisStever Pro Tools 9 4 09-17-2012 03:19 AM
Protools Crashes at Launch (Every Time) jeffmercel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-20-2009 11:37 PM
Protools LE 7.1.1 crashes on launch BGMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-14-2007 11:55 AM
Installing PT 6.0.1 update crashes my computer Mike Thornton Pro Tools TDM Systems (Mac) 17 08-04-2003 06:45 AM
