Old 02-11-2015, 08:34 PM
zudubat zudubat is offline
Default count off issues
hey guys im a fairly new pro tools user and im having an issue i cant figure out. When recording the count off is rarely on time. for example im trying to punch in at 73/3/00 so the count off is set for two bars but it will count the two bars plus one and a half. Obviously this is hindering the recording process as it is always changing. any ideas?
Old 02-11-2015, 09:29 PM
albee1952 albee1952 is online now
Default Re: count off issues
Not sure. Is timing set to 4/4? Maybe post a screen shot?
Old 02-11-2015, 10:00 PM
Old 02-12-2015, 12:03 AM
I cannot see from the small/fuzzy screenshot what the visible bar labels/numbers are and if the bar markets actually live up with the recorded audio. You have a conductor track enabled, but we can't see the tempo track in the screenshot either. What is the tempo set to? Where you are trying to do the count in?
Old 02-12-2015, 12:27 PM
Well I'm trying to open it up to take another screen shot but now it's saying "the current playback engine does not support a sample rate of 48kHz"?
How I currently have the playback settings
Old 02-12-2015, 01:42 PM
What the hell is "Instant On Sound Effects"? What Audio Interface are you trying to use?
Hold down the 'N' key while Pro Tools is starting and select the correct interface in the playback engine dialog when it appears, "Instant On Sound Effects", whatever that is, is not ever going to be the right playback engine.
Old 02-12-2015, 02:40 PM
It's always been on that setting since I started using pro tools. I'm using the digidesign eleven rack as the interface
Old 02-12-2015, 02:49 PM
Then "Eleven Rack" should be the interface named in the Playback engine dialog. Start by getting that set up correctly (do not try to use an aggregate IO device). Make sure you have the correct Eleven Rack drivers installed. And do what I said to select the correct interface on start up.
Old 02-12-2015, 08:52 PM
Thanks for the help Darryl, now here's a better screen shot for the count off issue. I have it set at 4/4
Old 02-12-2015, 09:34 PM
so pretty much unless the bar is at an even number (63|1|00) the count off will add extra clicks. Right now im trying to punch in at 63|2|00 so the click counts - 1,2,3,4, 1,2,3,4,5.....
2 Bar count in help!!!! mikewojtkiewicz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-25-2010 09:42 PM
PT 7.1 bus count Micah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-15-2009 09:35 PM
Performance issues - plugin count ect... Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-08-2008 10:20 AM
Bus Count chriscalyx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-08-2007 03:14 PM
Down for the count for a while....computer issues superpenguin79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 10-15-2004 08:44 AM
