Old 02-09-2015, 09:41 PM
blizzard's Avatar
blizzard blizzard is offline
Default mp4 to DNxHd - File size 10x larger
Hey All,
I am receiving mp4 from my director and have been converting to QT using H264. After reading more about which codec to use I am experimenting with DNxHD. When using Streamclip to convert to DNxHD the file size is increasing ten-fold. From 99MB to 9GB!
Is there a better way to convert these? Any specific settings I should be trying? Avid talks about how DNxHD allows smaller file sizes for ease of use but I am not seeing that at all.
Thanks for any help you can offer.
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2021.7 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.5
Old 02-10-2015, 04:02 AM
YMAaron YMAaron is offline
Default Re: mp4 to DNxHd - File size 10x larger
Originally Posted by blizzard View Post
Hey All,
That's the standard size for a 30 minute programme I'm afraid. Nothings going wrong - that's just how it is!
Old 02-10-2015, 05:12 AM
Craig F Craig F is offline
mp4/h264 have a key frame then a bunch of change data instead of frames, the change data is CPU intensive to recreate the missing frames
when DNxHD or Pro Res is talked about, they're are taking about down from the RAW uncompressed camera data
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 02-10-2015, 05:20 AM
Speedsound Speedsound is offline
try DNXHD 36 8bit
It should be lighter...
Hey All,
Old 02-17-2015, 04:15 PM
blizzard's Avatar
That's the thing, these are 6 minutes max.
Originally Posted by Speedsound View Post
try DNXHD 36 8bit
Sorry for the delay in posting...I have been busy with this:
http://duc.avid.com/showthread.php?t=364338
I have reformatted my Windows 7 machine from scratch and still have some issues with PT freezing. I want to make sure that I eliminate as many possible video engine related problems (if not all of them...haha) to help determine what is causing my instability.
I don't have the option for 36 8-bit in MPEG Streamclip. I have the following
720p/23.976 DNxHD 90 10-bit
720p/23.976 DNxHD 90 8-bit
720p/23.976 DNxHD 60 10-bit
Also are there any additional settings within Streamclip that would help in PT? Frame size/blending, Alpha compression, etc... Working with Video is still somewhat new to me within PT.
Old 02-18-2015, 04:15 AM
tom_lowe tom_lowe is offline
DNxHD36 is oddly only available for 1080P footage. And it's simple mathematics. Those settings are 90Mbps and 60Mbps, your MP4 could only be 5-6Mbps, so a 10x increase is correct.
Old 02-18-2015, 12:15 PM
smurfyou smurfyou is offline
Is the file size a problem? A 20+GB DNx will play much better than a 1GB MP4. Its not the size, its the codec that matters.
~Will
Old 02-18-2015, 01:02 PM
blizzard's Avatar
Okay this is all making much more sense now. And I am noticing so far that the larger DNxHD does really play better that the smaller. My learned habit of smaller file size = faster playback is hard to kick.
Thanks for the advice everyone.
Old 02-19-2015, 04:19 AM
Yes but remember don't go too far as surely you're putting massive strain on your hard drive reading that amount of data to play the video. You do have a separate video drive don't you?
Old 02-19-2015, 08:08 AM
blizzard's Avatar
I have two SSD that host my samples for all my VI's, and I keep all my video that I'm scoring to on one of those. I'm thinking of getting another SSD soon though, and will likely use it for video and rarely used samples.
HTML code is On
PT 10 Export WAV---Larger File Size JLeigh2024 macOS 10 06-22-2016 07:44 PM
File size too big jordan_ellipsis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-31-2006 10:28 AM
odd file size duanebonney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-18-2002 08:33 AM
Larger Minimum File Sizes?? simonjbinks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2002 08:57 AM
quadruple file sizes larger than they should be?! DeafinONEear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-28-2002 10:22 AM
