Old 11-17-2014, 08:47 AM
musicmixer04 musicmixer04 is offline
Default open .pts files in PT 11. possible?
Hi Im currently moving all my sessions over to my PT11 HD native rig. I have a ca 200 session made on an old PT Mix system. PT 6.4.1 The .pts files are not recognized by PT 11HD.
what I have to do is open the .pts sessions on my PT 10 rig , then save session copy in, to make a new session file .ptx and then I can open the project in PT 11
This Is a very time consuming process, Is there any possible workarounds to open .pts in PT11?
Thanks
Old 11-17-2014, 08:50 AM
Craig F Craig F is offline
Default Re: open .pts files in PT 11. possible?
make a new session in 11 then use Import Session Data to import the old .pts sessions
not as fast as direct opening but faster than going through 10
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 11-17-2014, 10:47 AM
sw rec sw rec is online now
Or open it in PT 11 and immediately do a "save as.." I do this all the time, and maybe it's my imagination, but if I open, save as, close, re-open the new one it seems to operate more smoothly.
Old 11-17-2014, 12:21 PM
Assuming the new system is the same platform as the old??(Mac or PC)
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 11-17-2014, 01:06 PM
Top Jimmy's Avatar
Yeah, and Mac/PC compatibility enforced. Archiving unenforced sessions on DVD or on Windows from Mac could very well be causing issues.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 11-17-2014, 05:05 PM
I have 3 systems
My Old PT Mix 6.4.1 which I run on PC with all sessions mac compatible checked
PT 10 on macbook Pro 2011, All the 6.4.1 .pts files opens just fine
PT11HD on macbook pro late 2013, .pts files are not recognised by the system, just a grey square with exec in green writing.
Only way that works is open the .pts files first in PT 10 and save as .ptx, then PT11 can open the files.
Interresting. any specific improvements? I have noticed some bugs with ADC not working properly when open PT 10 sessions in PT 11 HD. maybe this will do the tricks
Old 11-17-2014, 06:34 PM
Top Jimmy's Avatar
I just tested this with a .pts created on a Windows machine and opened in PT 11 on Mac. Trying to double click the .pts just gave me an error, but I was able to start Pro Tools and then open the .pts from the file menu just fine.
James Cadwallader
Old 11-19-2014, 03:44 PM
It worked. thanks :O)
Old 11-19-2014, 10:29 PM
JFreak's Avatar
JFreak JFreak is online now
PT11 dropped support for PT4.x and earlier, but PT5.x and newer sessions should be readable.
Janne
Old 04-05-2017, 10:09 AM
randyE randyE is offline
thanks, man! so glad i found this. i've been importing audio since i couldn't open the sessions but opening them from PT did the trick. woot!
.sib .soc files don't open jeremy_235 Avid Scorch (iOS) Forum 1 08-17-2011 01:45 AM
can you open PT 7.0 files in 6.9? schpilkas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-11-2007 01:35 AM
can i open 7.1 files in 7?? GStyle Pro Tools M-Powered (Win) 2 07-02-2006 05:00 AM
can't open files session files .....plz help... syntax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-19-2004 07:09 AM
can PT LE 5.0.1 open 6.0.1 TDM files? jaffaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2003 09:53 AM
