Old 03-12-2014, 08:03 AM
mirolalune mirolalune is offline
Default Activating Pro Tools LE 7 in Virtualbox on OS 10.6
Hi
Every time I try to get Pro Tools LE 7 working in Virtual Box on Snow Leopard Server it generates the following message
The machine is a MacbookPro 9.1 running OS 10.8.5
Failed to attach the USB device Digidesign Mbox 2 [0140] to the virtual machine Snow Leopard.
USB device 'Digidesign Mbox 2' with UUID {a8504fe7-d71f-41f9-8e2e-3492e93cde56} is busy with a previous request. Please try again later.
Result Code: NS_ERROR_INVALID_ARG (0x80070057)
Component: HostUSBDevice
Interface: IHostUSBDevice {173b4b44-d268-4334-a00d-b6521c9a740a}
Callee: IConsole {8ab7c520-2442-4b66-8d74-4ff1e195d2b6}
I've tried to activate the mbox in the menu and by the menu bar but nothing seems to work.
Any advice on this would be great
Thanks
Old 03-12-2014, 09:30 AM
tom_lowe tom_lowe is offline
Default Re: Activating Pro Tools LE 7 in Virtualbox on OS 10.6
I don't think Pro Tools is qualified to run in Virtual Machines. Considering they can have issues with accessing drivers I'd advise run it on the OS or on a separate partition.
Old 03-12-2014, 10:28 AM
Craig F Craig F is offline
Pro Tools can not see the USB port correctly through the Virtual Box interface
Not an uncommon problem with virtual machines in general
So give up on it now unless you are a master programer and want to spend the next year tweaking VB
Thank you,
Craig
HTML code is On
Issues activating Pro Tools [solved] Lehsyrus macOS 4 09-03-2013 11:19 AM
11R and Vitualmachine/Virtualbox SteveD@avid Eleven Rack 0 08-27-2011 02:47 AM
Pro Tools 9.0.2 freezing on activating inserts CatalystMusic macOS 0 05-23-2011 11:42 AM
Activating Pro tools LE 8 Afact 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-16-2011 08:55 AM
Anyone using Sun VirtualBox to run Windows??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-11-2009 02:09 PM
