I/O showing incorrect info on edit screen
Hi guys.
Quick question; On the edit screen of PT9, it is showing the inputs and outputs as "in-built microphone and build-in output" respectively, yet my it is my PreSonus sound card that is providing this. I've attached a screen shot of my Audio MIDI setup. I'm sure there is a simple explanation. Thanks.
Pro Tools 9, iMac 2.8 i7, 12 GB RAM, OSX 10.6.8, 2TB HD |
Re: I/O showing incorrect info on edit screen
Youve got the playbeck engine set to pro tools aggregate instead of the presonus. go to the playback engine and set the audio engine to the presonus Chris
Ok, I did that, but I'm a little confused at the PT layout; I've attached a screen shot showing my I/O setup and so forth. It is showing the PreSonus as the playback engine, yet still showing built in mic/ output on the edit screen. I'm also a little confused at the Audio Devices window; I deleted the Pro Tools Aggregate Device but I can't configure the PreSonus; right clicking "Configure device" does nothing. When I re-launch PT, the Pro Tools Aggregate device is shows up again with a title black drop down triangle to the left of it. I've attached another screen shot sowing all my current settings. Am I missing something here?
Video File Not Showing Up/ Black Screen | jleven22 | macOS | 0 | 12-19-2013 09:30 PM |
Trackball cursor not showing on profile screen | borez | VENUE Live Sound Systems | 0 | 07-20-2011 04:37 AM |
System Usage window showing incorrect info | poly915 | macOS | 2 | 03-18-2011 02:18 PM |
Screen not showing current state of D-Show | Lee Lundgren | VENUE Live Sound Systems | 2 | 07-12-2010 10:00 PM |
The main screen in PT isn't showing up? | rightsidefalls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-01-2004 12:14 PM |
