Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Old 11-11-2013, 03:31 PM
Bjt Bjt is offline
Default Ipad retina no playback
I have just upgraded to an ipad retina. Scorch was working fine on my old ipad2 but know I have no playback. Scorch v 1.2. I have checked the obvious ,mute switch, rebooted but still no sound.
Old 11-15-2013, 05:35 AM
dperry90277 dperry90277 is offline
Default Re: Ipad retina no playback
The issue is not just the retina devices, i upgraded my iPad 3 and i no longer have audio playback ;-(
Old 04-03-2015, 12:49 PM
fito fito is offline
I just downloaded avid scorch for my ipad 3 and I was able to share my sibelius 7 files, everything seems to run well except there is no sound. I see that other forum members posted the same issue a long long time ago and there is no answers yet. please help. I got a recording session right now!!!!
Old 04-22-2015, 07:35 AM
Sibelleux's Avatar
Sibelleux Sibelleux is offline
Hi All,
Could you try this please?
- Try the example scores
- Restart Scorch
- Restart your iPad.
- Check the mixer settings within Scorch
- Make sure the mute switch on the side of your iPad is not engaged.This affects Scorch playback even if the volume is turned up. If you are setting the side switch to the "Lock Rotation", please try to switch it to the "Mute" mode in the System Preferences?
https://support.apple.com/en-us/HT204171
Retina Macbook 13" ? (PT 11) JFrazier macOS 0 01-07-2014 08:52 PM
Pro Tools LE 6.8.1 MBP retina 10.8.4 berty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-16-2013 01:04 AM
PT 11 Support for Retina Display...? ronwasserman Pro Tools HDX & HD Native Systems (Mac) 2 04-22-2013 05:43 PM
Mbox 2 & MacBook Pro Retina Dreamwaver Avid Scorch (iOS) Forum 0 02-18-2013 05:04 PM
Pb of CPU use under PT10 with Retina kolargol macOS 5 01-13-2013 01:54 AM
