Old 06-17-2013, 04:28 PM
gavriil1 gavriil1 is offline
Default MIDI Volume or Velocity Change results in part muted MIDI sound
Hi guys. This happens intermittently (not sure what is different when it happens). When I make a MIDI, or a MIDI velocity change volume (to a part of my score), many times, my instrument sounds like it's part muted. I use an Oxygen 88 controller. Any ideas?
Old 06-17-2013, 04:47 PM
Default Re: MIDI Volume or Velocity Change results in part muted MIDI sound
I have filtered it down to an Xpand2 problem. Because restarting PT10 or restarting the controller, did not help. Because the way to go around this I had to:
1. Create a new track
2. Alt-Copy Xpand to the new track
3. Copy my MIDI notes to the new track
At this point the problem is still there.
Only when I click to a different Xpand instrument (say I go one instrument up with the plus button) and THEN come back down to my initial instrument (click on the minus button for one down), I get the instrument to respond with all "its might". What am I missing here?
Old 07-01-2013, 10:23 AM
Bump. No one guys has any clue?
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
how change a audio track snare to Midi for trigger a new sound? markolone Pro Tools M-Powered (Win) 15 12-14-2010 06:25 AM
Consolidate Muted Midi Region = Deleted Midi Events cheeseandpepper MIDI 9 11-11-2009 06:36 PM
I pan the MIDI track and get volume change- Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-30-2003 04:03 PM
Midi volume/velocity changes shacke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-02-2003 01:09 AM
