Old 01-03-2013, 12:58 AM
David2934 David2934 is offline
Default Korg nanoKONTROL2
Hello Everyone,
For all of the users that are using the Korg nanoKONTROL2 and are having issues with the LED's not lighting up when they are supposed, there is a fix.
After searching through various forums I found the fix and I thought i'd share it with all of the users on the AVID Forum. The fix is to simply run Protools as an administrator.
Or:
You can change the privileges on the protools.exe. In Windows 7 Right click on "protools.exe" click properties and then set your Windows 7 user account to "Full Control" save and try running protools with the Korg nanoKONTROL2 attached and hopefully the backlight LED's come on.
I hope this helps any of those having the same problem that I was.
Let me know if this helps,
David
nanokontrol2 and pro tools express hotpies Third Party Interfaces 1 09-03-2014 10:40 AM
Pro Tools 10 with Korg NanoKontrol2...? Vaernima Windows 5 02-23-2012 04:34 AM
korg m3m with pte eddie lamb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-24-2007 12:00 AM
Please.......! some help with Korg? Gons Deejay MIDI 1 05-04-2005 10:43 AM
Pt and the korg er-1 (anyone?) Ssaidvox1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-11-2001 07:12 PM
